cam angle sensor? dohc zc
im getting ready to swap a zc into my 88 hf and i know the harness will match up except for i have to change two wires at the distributor(i know which wires they are but not quite sure what they do) to the cam angle sensor on the zc motor. does anyone know where the clip is located or can help explain this more to me. pictures would help alot to if anyone has them.
There are actually 7 wires to change, and they are all on the engine harness side. 2 need to be extended to the CAS, the other 5 need to be pulled from the dizzy plug & re wired into a teg dizzy plug (88-89 teg square plug)
if the ZC comes with a distributor, you dont have to repin the entire distirbutor plug. all you have to do is remove the blue and green and the blue and yellow wires from the distributor harness and extend them to the front side of the head.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sobe_Death »</TD></TR><TR><TD CLASS="quote">if the ZC comes with a distributor, you dont have to repin the entire distirbutor plug. all you have to do is remove the blue and green and the blue and yellow wires from the distributor harness and extend them to the front side of the head.</TD></TR></TABLE>
you still need to repin the distributor harness because it is circle shape while the distributor is square...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxgator »</TD></TR><TR><TD CLASS="quote">
you still need to repin the distributor harness because it is circle shape while the distributor is square...</TD></TR></TABLE>
Square plugs exactly the same as DPFI 88-91 cx/dx/lx
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Garrett »</TD></TR><TR><TD CLASS="quote">
Square plugs exactly the same as DPFI 88-91 cx/dx/lx</TD></TR></TABLE>
he doesnt have a square plug...
I have a '91 Si and just bought a DOHC ZC to install. The ZC does not have a distributor. I thought I saw mention of using the Si distributor on the ZC, but I also heard you must use the 88-89 Teg dist or ZC. Not sure this makes sense about the Si working since the Si is not DOHC? Can anyone clarify this for me?
Also, as far as dropping the ZC into the Si everything as far as wiring goes plugs right in, I've heard, with one exception. I've come up empty in all my searches as far as what wire(s) need to be added to complete a ZC into an Si swap. Everthing I've seen speaks about a ZC into a DX. I would REALLY appreciate someone's guidance.
Thank You
Thank You
Crxkustoms
Sep 14, 2004 07:31 PM
