k20a2 or k24a2?
Old Feb 26, 2005 | 05:59 AM
yagotrice's Avatar
Default k20a2 or k24a2?
What are the differences between the k20a2 and the k24a2 as far as power potential? I'am interested in doing a swap but can't decide which one to go with. I've read about the k20a2 but havent found to much on the k24a2, so if anyone can shed some light on the k24a2 would be great.
Old Mar 28, 2005 | 07:41 AM
doublethink's Avatar
Default Re: k20a2 or k24a2? (yagotrice)
im also in the market for a K and im wondering which K comes in what car stock, are the trannys interchangable?
what i know so far:
k20a-r = Jdm RSX Type-R
k20a2 = Usdm RSX Type-S
k20a3 = Usdm Civic SI
k24 = TSX or TL? What type of tranny, redline? If i drop it in stock internals (bc ill be out of money by then ) Worth it?
Old Mar 28, 2005 | 09:52 AM
Professor15's Avatar
Default Re: k20a2 or k24a2? (doublethink)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by doublethink &raquo;</TD></TR><TR><TD CLASS="quote">im also in the market for a K and im wondering which K comes in what car stock, are the trannys interchangable?
what i know so far:
</TD></TR></TABLE> i believe the Tl has a single cam J- something engine. The k24 came in the tsx, element,crvs and accords. The element, accord and crv come with 9.6 CR while the tsx comes with 10.5 CR. If your planning on using a k24 block use either the tsx or crv....the other two will cause piston to valve contact. and im not sure on the trannys though....
Old May 11, 2005 | 06:53 AM
Nikos's Avatar
The TSX k24a2 is a completelly different motor than the other k24a.. It is basically a rsx type s motor but with 2.4L , so instead of 86 x 86 it is 87 x 99.
It also has oil squirters like the k20a and k20a2.
Honda stock ecu, redlines it around 7100 but we take it arounf 7500 and I have seen a few people take them up to 8200 but better rods would be a good idea.
eg_ruoner364
19
Jul 8, 2008 08:08 PM
Stumpy
Oct 29, 2004 05:49 PM
siR cr-x
Jul 17, 2004 09:01 AM
04accordcoupe
38
Sep 24, 2003 04:21 PM
Senses Fail y0!
Jun 15, 2001 11:34 AM
