How to turn off "required maintanance" light on 04 civic si
Can someone tell me the procedure for turning off this light on my dash. My odometer just turned 10k and it came on.
Thanks in advanced!
Thanks in advanced!
have you checked your owner's manual?
insert key in. while pushing right reset button in dash, turn ignition key to "on/ II". push reset button for 10-15 seconds. release, turn ignition key back to "I".
voilah!
voilah!
http://www.searchbuttonintheri...n.com
yields 7 results.....
on every honda i ever been in its in the same spot
when your sitting in the drivers seat, take your right hand and put it under the dash, directly below the steering wheel, a little to the right , search around under the dash its on the edge, its a little box like a 2x2 box with a button on it, puch it in the light will come on, hole the button in untill the light goes off
now i cant guarentee your button will be in the same spot, as iv never sat in a rsx or ep3, but like i said its been in the same spot in every other honda iv been in, and iv been in alot of them
if all else fails get down on the floor and look up under the dash on the edge
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 01-0720 »</TD></TR><TR><TD CLASS="quote">on every honda i ever been in its in the same spot
if all else fails get down on the floor and look up under the dash on the edge</TD></TR></TABLE>
The reset button on the EP3 is the same as the odometer reset button underneat the speedometer
