D16 minime or ls vtec which do you recommend
Old Feb 25, 2005 | 11:28 PM
srv3fender's Avatar
Default D16 minime or ls vtec which do you recommend
Ok looks like im gonna be doing the minime d16y8 swap in my hatch/rex
I really want the ls vtec but cant afford it right now
Can someone tell me how badly i would get beat against same car with the ls if im running the minime
and would there be anything i could do to meet the power of the ls realatively reasonably (not like nos or turbo)
And also if in the future i get an ls/vtec, how difficult is it to swap the minime out
thanks guys
preciate it
Old Feb 26, 2005 | 12:03 AM
ekb16's Avatar
well it all depends if u have money.. cheap way is prob. the mini me but you would need to build it prob to keep up wit the ls...there is a rex where i live that has a minime that runs 12s..i think its built or its usin nitrious...
Old Feb 26, 2005 | 11:51 AM
jsw_1986's Avatar
Default Re: D16 minime or ls vtec which do you recommend (srv3fender)
why wouldn't you want to use nitrous? if you use it for only when you go to the track your engine should withstand it, depending upon the size shot. with a 55-75 shot you should have no prob taking out an ls and a gsr. also nitrous is cheap. you can pick up a kit for as low as $250 off a h-t member. anyways keep us posted on what you decide to do
Old Feb 26, 2005 | 03:06 PM
Swapped_EG's Avatar
if i were you i would just save up to build a ls/vtec. it'll be worth it. that is if you build it right. a ls/vtec buikt right will run its as off. but on the other hand i've seen them run like ****. my boy had one in his Si and i could keep up with it when my b16 eg was stock. but then again i got one of those rare honda freak motors.
94icxhatch
Aug 12, 2013 03:54 PM
94hatchvx
Jan 25, 2007 03:49 PM
allhonda
Jan 8, 2007 05:47 AM
srv3fender
Mar 1, 2005 09:16 AM
mkim12180
Jul 4, 2004 10:42 AM
