91 integra belt warning box?
Old Feb 25, 2005 | 10:16 PM
tgibson10's Avatar
Default 91 integra belt warning box?
I tried to start my car one evening and as soon as I turned the key all the cluster lights went off and a relay started buzzing. I found under the passanger side kick panel. All it does is switch on and off very rapidly, no key just by having the battery connected. On the outside of the metal box a tag says belt warning, has two plugs on the bottom a green and brown if I recall correctly. Anyone have any ideas? They would be apreciated.
Old Feb 26, 2005 | 01:29 AM
AzBlackTeg's Avatar
Default Re: 91 integra belt warning box? (tgibson10)
that happened to me once all I did was pop out the green plug and bamn left it like that for a while and then pulled my seat belt back and than took out the fuse from the engine bay and than a month later I put everything back and since had the problem again. Try unplugging the green plug than replug it back in. wish I could help
Old Aug 14, 2022 | 11:53 AM
dano171's Avatar
did u ever fix the issue I am facing the same problem and can’t find answers anywhere.
Old Aug 16, 2022 | 10:53 AM
Maxcapacity's Avatar
Try just unplugging the box and see what happens..
accordin 2 me
12
Jul 13, 2010 02:45 PM
freddysEF
Nov 6, 2007 09:11 PM
CeNCaL-DA9
Aug 3, 2007 02:13 PM
Jimmy
Jun 1, 2005 12:49 PM
2live4tv
Jul 1, 2004 01:48 PM
