headlights flicker when touching brakes...
Old Feb 25, 2005 | 07:52 PM
RTW DC2R's Avatar
Default headlights flicker when touching brakes...
I dont remember this happening before I installed this new block. As soon as I apply any amount of brake pressure, my headlights flicker and then come back on like normal. Im pretty sure all the grounds are secure(Ill double check tomorrow), the alternator belt is snug, and battery is fairly recent. What else should I look for? Im not too great with electrical ****.
Old Feb 25, 2005 | 08:31 PM
Opie's Avatar
You just named all the things I would have told you to double check.
Old Feb 26, 2005 | 04:47 AM
Cosworth's Avatar
Default Re: headlights flicker when touching brakes... (RTW Ryan)
flux capacitor. if not, alternator gone bad?
Old Feb 26, 2005 | 05:11 AM
RTW DC2R's Avatar
I hope not...time to bust out the Helms.
Old Feb 26, 2005 | 05:39 AM
Chris F's Avatar
Default Re: (RTW Ryan)
Yo!
I was guessing wiring harness jiggling loose... except you said touching the brake with "any amount of pressure".
If I was you, I'd check it again with the car stopped. Touch the brake, see what happens. If it does the same thing with the car stopped...
-- Alternator/battery (hope not)
-- bad ground from the battery to chassis, or anywhere else for that matter
One small note, light bulbs draw much more current when you first turn them on. When cold their resistance is very low. When they heat up (that filament is VERY hot), their resistance is a lot higher. That would explain why they dim and then come back, if you had some grounding/bad battery/etc.
Old Feb 26, 2005 | 05:46 AM
uNF$@#!'s Avatar
Default Re: (Chris F)
*jiggle jiggle*
lol
sure sounds like a bad ground somewhere....or a dead alternator
Old Feb 26, 2005 | 06:55 AM
RTW DC2R's Avatar
definitely not something jiggling lol If I press the brake just light enough to get the brake lights to come on, it still does it. If it was a bad alternator or battery, then wouldnt I most likely be seeing some rough starts, sorta like a weak battery? Thats not happening. Maybe Ill just get one of those grounding kits and redo all the grounds.
Old Feb 26, 2005 | 07:09 AM
Mugen Mike's Avatar
Default Re: (255.255.255.255)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Soup **** &raquo;</TD></TR><TR><TD CLASS="quote">sure sounds like a bad ground somewhere....</TD></TR></TABLE>
Old Feb 26, 2005 | 07:15 AM
ZygSpeed's Avatar
From your latest post ... I'd also start checking for some type of short in and around the brake pedal switch.
Just a guess. Good luck finding it. Ed
Old Feb 26, 2005 | 07:24 AM
Bradstard's Avatar
Default Re: (zygspeed)
Turn the key to the on position and turn the headlights on. Hit the brakes and see if they dim. If they dim without the car running then you have a ground problem. It if only does it while the car is running I bet it's your alternator.
Old Feb 26, 2005 | 08:05 AM
Chris F's Avatar
Default Re: (Fat Bradstard)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Fat Bradstard &raquo;</TD></TR><TR><TD CLASS="quote">Turn the key to the on position and turn the headlights on. Hit the brakes and see if they dim. If they dim without the car running then you have a ground problem. It if only does it while the car is running I bet it's your alternator.</TD></TR></TABLE>
He did say "flicker", not dim.
Like Ed said, check wires around brake pedal. GL.
Old Feb 26, 2005 | 08:40 PM
TypeRPaul's Avatar
are u running stock ecu or hondata? because with my hondata it does the same thing
Old Feb 27, 2005 | 06:48 AM
RTW DC2R's Avatar
stock ECU
mike9571
Nov 28, 2005 08:42 PM
b00sted4dr
May 30, 2005 09:53 PM
spicoli
10
Sep 22, 2004 05:45 PM
loopid
Dec 28, 2003 10:45 PM
civcexcoupeblack
Jun 23, 2003 04:34 PM
