HELP!!!!
Old Feb 25, 2005 | 07:38 PM
crxkid24's Avatar
Default HELP!!!!
my car has recently started missing...like when i'm driving at about 50 mph its starts missing. i've tried replacing the plugs, cap, rotor, wires, ignitor, coil and NOTHING. still does it. i even tried a different dizzy. i have no clue what it is. someone help me!!! thanks.
Old Feb 25, 2005 | 07:46 PM
s2k_al's Avatar
Default Re: HELP!!!! (crxkid24)
You could have named ur topic somthing else i just started a topic named HELP!!! like 3 seconds ago
Old Feb 26, 2005 | 01:14 PM
crxkid24's Avatar
dude who cares?
Old Feb 26, 2005 | 02:06 PM
superbeastcrx's Avatar
Default Re: (crxkid24)
check your fuel pressure, it might help
Old Feb 26, 2005 | 02:18 PM
ef8 h0!'s Avatar
Default Re: HELP!!!! (s2k_al)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by s2k_al &raquo;</TD></TR><TR><TD CLASS="quote">You could have named ur topic somthing else i just started a topic named HELP!!! like 3 seconds ago </TD></TR></TABLE>
someone has to be the i337 one here on ht, but anyways, it may be something stupid liek a fuel filter. the first thing id say do it check fuel pressure.
Old Feb 26, 2005 | 02:22 PM
SexyAzNMami's Avatar
what do you mean by " missing "? I think mines is doing the same thing but i dont call it missing and i was wondering how to fix it also.
Old Feb 26, 2005 | 03:31 PM
bagpipe goatee's Avatar
ok, could be spark, compression, or fuel.
it seems you have spark taken care of.
someone else mentioned fuel
if your headgaskets starting to go, it could have those symptoms.
also, this might make you feel dumb, but make sure your sparkplugs didn't work their way loose.
Old Feb 28, 2005 | 08:27 AM
crxkid24's Avatar
well i kinda fixed it i guess. it was the o2 sensor. when i unplug it the car runs fine. but when its pluged in it misses. i tried a new 02 sensor and it still did it. so i left the damn thing unpluged until i can figure it out. lmk what you guys think.
Old Feb 28, 2005 | 08:44 AM
nucivowner's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxkid24 &raquo;</TD></TR><TR><TD CLASS="quote">well i kinda fixed it i guess. it was the o2 sensor. when i unplug it the car runs fine. but when its pluged in it misses. i tried a new 02 sensor and it still did it. so i left the damn thing unpluged until i can figure it out. lmk what you guys think.</TD></TR></TABLE>
thats awsome. well if you unpluged the o2 it obviously has something to do with fuel. now you have a vague idea. work at it from there. it could even be a pluged injector.
Old Feb 28, 2005 | 09:11 AM
NikoZai's Avatar
Default Re:
Not a plugged injector if removing the O2 fixes it.
Maybe you should test a different ECU... that's weird that it's missing and replacing the dizzy/plugs didnt help.
From what i remember, fuel not getting to one cylinder didn't feel like a cylinder is "missing" because if it can't keep flow after a certain RPM, it feels like 3 cylinders (no power, but steady) Missing spark sounds like sputtering. "ra-tat-tat-tat" over and over.
Old Feb 28, 2005 | 09:18 AM
91 HONDAsaurus rex's Avatar
Default Re: Re: (NikoZai)
check fuel and for the hell of it do a compression test. I had same problem and just did a tune up and everything was fine. Check the fuel filter I think that was my main problem because the spark plugs werent that bad.
sleepin91teg
Feb 27, 2004 11:05 PM
