Mugen MR5 rivet/bolt torque specs?
Old Feb 25, 2005 | 04:03 PM
FR-MOB: ThE bEe GuY's Avatar
Default Mugen MR5 rivet/bolt torque specs?
I have some Mugen MR5's I want to take apart to repolish (since theyre 2 piece). Does anyone know the torque specs I need to tighten all the rivets/bolts that hold the face on to the rim to? i searched but the only guy that asked that question before, hasn't posted on here for over a year.
Old Feb 25, 2005 | 04:15 PM
LoSt is BlaCk's Avatar
Default Re: Mugen MR5 rivet/bolt torque specs? (ThE bEe GuY)
don't worry about the specs, just let me have them
Old Feb 25, 2005 | 04:18 PM
Default Re: Mugen MR5 rivet/bolt torque specs? (LoStMyBoOst)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LoStMyBoOst &raquo;</TD></TR><TR><TD CLASS="quote">don't worry about the specs, just let me have them </TD></TR></TABLE>
Muahaha, you aint gettin these jus like you aint gettin my old meshies
I better see you at the Eibach meet bastard! THat EF is the sickness
Old Feb 25, 2005 | 04:42 PM
01-0720's Avatar
im not sure on the torque specs, but i remember reading somewhere
that your not supposed to take the apart and put them back to together yourself
they need to be rebalanced and torqued in a certain sequence or thell never be true again
Old Feb 25, 2005 | 05:07 PM
robertw's Avatar
Default Re: Mugen MR5 rivet/bolt torque specs? (01-0720)
beeeeeeeeeeeeeeeeeee VERY VERY VERY CAREFULL with that
i took mine to a shop to have them polished
they came back looked great, threw them on the car drove all day and then nightfall, took a corner one wheel completly seperated, the bolts were overtorqued
sold that set. got a new set had those polished at a different shop and i have had good luck.
i talked to the guy in japan that i got them from and he said for liability reasons mugen wont release the torque specs
so do this take a torque wrench with you when you take them apart good luck
robertw
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ThE bEe GuY &raquo;</TD></TR><TR><TD CLASS="quote">
I better see you at the Eibach meet bastard! THat EF is the sickness </TD></TR></TABLE>
LMAO! you know if i had them mesh joints it would be on and crackin! i'll see you at the eibach meet for sure homie, i can't wait
Old Feb 25, 2005 | 05:39 PM
Default Re: Mugen MR5 rivet/bolt torque specs? (robertw)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by robertw &raquo;</TD></TR><TR><TD CLASS="quote">beeeeeeeeeeeeeeeeeee VERY VERY VERY CAREFULL with that
robertw</TD></TR></TABLE>
Hmmmm.... Guess ill do them the hard way then and just mask up the face n stuff and be careful not to accidently polish the face
Thanks guys
Old Feb 27, 2005 | 04:55 PM
JDM_CD7's Avatar
OH ****... Finally got the wheels. Let me know if you need some help.
Remember i got the whole polishing kit for the wheels. I'll leave your **** on BLing Status.
P.S. ==&gt; "You'll never defeat the Cobras"
Old Feb 27, 2005 | 11:00 PM
Default Re: Mugen MR5 rivet/bolt torque specs? (JDM_CB7)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM_CB7 &raquo;</TD></TR><TR><TD CLASS="quote">OH ****... Finally got the wheels. Let me know if you need some help.
P.S. ==&gt; "You'll never defeat the Cobras" </TD></TR></TABLE>
LOL its koo man i got the same kit at home, i aint got **** to do n e ways so imma jus do them when im not too lazy . Home Depot NIGGY! haha.
Old Feb 27, 2005 | 11:02 PM
drunknbass's Avatar
loc tite is your friend
Old Feb 27, 2005 | 11:15 PM
tONE.steR's Avatar
* B A N N E D *
Default Re: (drunknbass)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drunknbass &raquo;</TD></TR><TR><TD CLASS="quote">loc tite is your friend</TD></TR></TABLE>
Yup, each bolt should have loc tite and then bolted up/torqued.
Old Feb 28, 2005 | 05:42 PM
stickershop.ca's Avatar
Default Re: (Vita-Soy)
I've taken them apart and put them back together again. It's not a big deal. Just loc-tite the threads and torque them up to 10 ft/lbs of torque. That's a little more than hand-tight. They are small bolts, and there are a lot of them, so they don't need to be cranked too tight. Besides, you are boltin them into aluminum, and you most definitely *DO NOT* want to strip the threads out of the rim. As long as you are consistent with the torque, using your 12 point socket, and you torque them down in a criss-cross pattern around the rim, you should be perfectly fine.
Old Feb 28, 2005 | 08:22 PM
Default Re: (stickershop.ca)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stickershop.ca &raquo;</TD></TR><TR><TD CLASS="quote">I've taken them apart and put them back together again. It's not a big deal. Just loc-tite the threads and torque them up to 10 ft/lbs of torque. That's a little more than hand-tight. They are small bolts, and there are a lot of them, so they don't need to be cranked too tight. Besides, you are boltin them into aluminum, and you most definitely *DO NOT* want to strip the threads out of the rim. As long as you are consistent with the torque, using your 12 point socket, and you torque them down in a criss-cross pattern around the rim, you should be perfectly fine. </TD></TR></TABLE>
Ahh kool! Thanks a lot man!
Old Mar 1, 2005 | 02:18 AM
tONE.steR's Avatar
* B A N N E D *
Its more than 10ft/lbs b/c when I dissembled some blitz it was alot tighter than 10ft/lbs.
I'll find the exact amount soon, I just need to take them out the boxes b/c there are 2 I haven't started on and a the new Snap-On Tech Wrench (digital torque wrench) will read ft/lbs in/lbs in both directions.
Old Jul 16, 2005 | 01:38 PM
Vinceg99's Avatar
Yup had to bring it from the dead......
So did anyone ever find out the torque spec on the MR5's??
I just got a set also and you can only polish so much withOUT hitting the face so it would be a lot easier to take them apart.
Old Oct 7, 2006 | 10:54 PM
RICE POLICE SIP's Avatar
Default Re: Mugen MR5 rivet/bolt torque specs? (Vinceg99)
So is it 10ft lbs?
Old Oct 8, 2006 | 12:11 AM
1 point 6's Avatar
Down Since Day 1
Community Builder
Community Influencer
Default Re: Mugen MR5 rivet/bolt torque specs? (RICE POLICE SIP)
**** on my set they were just put on like you would any other bolt, they are fine 1yr later.
Old Oct 8, 2006 | 06:59 AM
Joon Joon's Avatar
Default Re: Mugen MR5 rivet/bolt torque specs? (1 point 6)
torque them at 10ft/lbs.. i would go in a criss cross pattern and use loctite.. i wouldnt mount tires on them for a few days..
85ZC
Sep 28, 2008 08:18 AM
-jacob-
Mar 23, 2007 07:41 AM
crxforum
Jun 29, 2006 10:50 AM
FR-MOB: ThE bEe GuY
Sep 12, 2005 11:38 PM
Thats-so-Ls
Apr 25, 2003 07:31 PM
