SSR Comp 15 x 7 + 205/50/15 S03 tires 4x100
Old Feb 25, 2005 | 03:49 PM
CRX-RX's Avatar
Default SSR Comp 15 x 7 + 205/50/15 S03 tires 4x100
Click for larger image
* $1300 + shipping *
Center Caps and Valve Caps
Wheel 1 front
Wheel 1 rear
Wheel 2 front
Wheel 2 rear
Wheel 3 front
Wheel 3 rear
Wheel 4 front
Wheel 4 rear
Tire 1 penny 1
Tire 1 penny 2
Tire 1 penny 3
Tire 2 penny 1
Tire 2 penny 2
Tire 2 penny 3
Tire 3 penny 1
Tire 3 penny 2
Tire 3 penny 3
Tire 4 penny 1
Tire 4 penny 2
Tire 4 penny 3
These rims are SSR competitions in silver. I purchased the SSR rims from Honda-tech member JeffS twoards the end of season last summer. I installed a set of Bridgestone Potenza Pole Position S03 tires in 205/50/15. This combo was used once in late october at an event at Gingerman Raceway for half of the day (had to shake out some problems on the white bastard in the background all morning), other than that, the wheels were never on my car and have been kept indoors.
The tires that were installed I had previously mounted on a set of rota slipstreams that I used for track days only. These tires have never seen street use, and probably have under 2,000 mi on them to date. That said, they were used at the track approx. 15-20 times, and have seen that many heat cycles as well. Plenty of tread reamins for regular street use, or even further track use. Two of the wheels balanced out without the use of weights at all! The other two requiring minimal weights, the results of a high quality wheel and tire combo. In the pictures I gave a quick clean on the two front wheels before I took the pictures to clean off the brake dust, and the two rears remain untouched since their track use.
One of the wheels has a couple off scuff marks on the lip and on the face of the spokes. I think these could be buffed out for the most part, I haven't tried. Below are a couple pics of the scuffing. The other three rims are in near new condition. They all have a couple of dimples on the backside of the rim from the tire mounting machine, nothing out of the ordinary. I'd say 9.5 out of 10 for three, and 9 out of 10 on the scuffed wheel, but can probably be brought back.
scuff1
scuff2
To sum it all up. Included items are as follows:
4 SSR Competition Rims 15x7 with a 42mm offset and 4x100 lug pattern
4 SSR aluminium vlave stems and caps
4 SSR aluminium center caps
4 Bridgestone Potenza Pole Position S03 tires in 205/50/15
*not included:
4 Hubcentric rings
4 Wires to hold in rings
16 Lugnuts
Get them before they're collectors items!!!!
Pic from the only time they were on the car
SSR Rim info according to Tirerack
Bridgestone Tire information also from Tirerack
Modified by CRX-RX at 7:00 PM 2/25/2005
Modified by CRX-RX at 7:01 PM 2/25/2005
Modified by CRX-RX at 7:44 PM 2/25/2005
Old Feb 26, 2005 | 11:32 AM
CRX-RX's Avatar
Default Re: SSR Comp 15 x 7 + 205/50/15 S03 tires 4x100 (CRX-RX)
Up 1
Old Feb 27, 2005 | 11:56 AM
CRX-RX's Avatar
TTT
Old Feb 27, 2005 | 09:02 PM
CRX-RX's Avatar
Old Feb 28, 2005 | 07:35 PM
CRX-RX's Avatar
BUMPER
Old Mar 1, 2005 | 10:08 AM
pierrot le fou's Avatar
nice setup
Old Mar 3, 2005 | 04:18 PM
CRX-RX's Avatar
Default Re: SSR Comp 15 x 7 + 205/50/15 S03 tires 4x100 (ronmcdon)
Thanks. Back up for another day
Old Mar 4, 2005 | 04:36 PM
PIC Performance's Avatar
Was that pic taken at Gingerman last year?
Old Mar 4, 2005 | 06:26 PM
CRX-RX's Avatar
Default Re: SSR Comp 15 x 7 + 205/50/15 S03 tires 4x100 (Noob4life)
You bet, and don't let the sunshine fool ya, it was cold, hahaha
Old Mar 5, 2005 | 02:28 PM
CRX-RX's Avatar
Going up, hehehe
Old Mar 6, 2005 | 04:56 PM
CRX-RX's Avatar
bump
Old Mar 7, 2005 | 03:17 PM
Shelton's Avatar
i like the rims
Old Mar 9, 2005 | 08:06 PM
CRX-RX's Avatar
Default Re: SSR Comp 15 x 7 + 205/50/15 S03 tires 4x100 (Shelton)
Thanks
Old Mar 9, 2005 | 08:19 PM
ejONE.mike's Avatar
nice wheels
Old Mar 11, 2005 | 04:24 PM
CRX-RX's Avatar
Default Re: SSR Comp 15 x 7 + 205/50/15 S03 tires 4x100 (JayDieM_ej1)
Yup
Old Mar 11, 2005 | 06:19 PM
aznboysrfr's Avatar
scuff pic shows a valve stem cap missing ;P
Old Mar 11, 2005 | 06:33 PM
CRX-RX's Avatar
Default Re: (aznboysrfr)
Yup, that's why they are pictured seperately. I don't need valve caps at the track
Old Mar 12, 2005 | 08:22 AM
aznboysrfr's Avatar
oh whoops ... didn't even see that.
Old Mar 13, 2005 | 07:37 PM
CRX-RX's Avatar
Bumnp cause I'm older
Old Mar 16, 2005 | 06:28 PM
CRX-RX's Avatar
Default Re: (CRX-RX)
up to bump
Old Mar 19, 2005 | 09:00 AM
CRX-RX's Avatar
bumping time
Old Mar 19, 2005 | 08:53 PM
CRX-RX's Avatar
up
Old Mar 20, 2005 | 07:41 PM
CRX-RX's Avatar
bump
Old Mar 22, 2005 | 04:59 PM
CRX-RX's Avatar
IP
Old Mar 23, 2005 | 04:55 PM
CRX-RX's Avatar
TTT
