Before i order this clutch, will someone verify it will work for my application?
Old Feb 25, 2005 | 09:56 AM
jadugartir's Avatar
Default Before i order this clutch, will someone verify it will work for my application?
Its going to be with this setup: a d16z6 motor with the d16z6 flywheel, a 90-91 Si tranny.
I have heard some places that all d series clutch are interchangable, i just want to be sure before i order that this clutch is right, heres the link.
http://cgi.ebay.com/ebaymotors...sting
Old Feb 25, 2005 | 10:30 AM
jadugartir's Avatar
Default Re: Before i order this clutch, will someone verify it will work for my application? (jadugartir)
bump
Old Feb 25, 2005 | 12:30 PM
jadugartir's Avatar
Gotta get this answered.... somebody know?
Old Feb 25, 2005 | 12:32 PM
Malgerus's Avatar
It'll work...
Old Feb 25, 2005 | 12:36 PM
jadugartir's Avatar
Default Re: Before i order this clutch, will someone verify it will work for my application? (Mr. S)
Okay i asked a friend on AIM and he said that he was worried that it may be for a hydro setup whereas mine is cable? is that just BS?
Old Feb 25, 2005 | 12:47 PM
Malgerus's Avatar
I used a 96 flywheel, clutch disc and pressure plate on my 89 transmission. I think that 90-00 D16 clutches are the same size. The hydro setup has nothing to do with it.
Old Feb 25, 2005 | 12:58 PM
CRseXy's Avatar
yah 90+00 D flywheels are the same. Diffrence between 89-90 is the Surfice area of the Clutch, witch means there bigger. a 89 clutch will not fit a 90 flywheel.
now from what I understand a 88 Trans has a diffrent spline count then the 89 trans. so a 88 clutch wont work on a 89+ tranny.
What I use as a rule of thumb. keep the same year flywheel\clutch\PP the same, and you will be alright.
Old Feb 25, 2005 | 01:12 PM
jadugartir's Avatar
Default Re: Before i order this clutch, will someone verify it will work for my application? (pogiTSI)
yeah but im gonna be using a 92+ motor and flywheel, and a 90+ tranny
Old Feb 25, 2005 | 01:56 PM
Aragorn's Avatar
If in doubt, you should use the set up for the tranny you are using, but I agree, the 1990 and up are the same. This page has the differences in sizes and spline counts:
http://thenew.gamesbbs.com/~dmoore/tranny.htm
Old Feb 25, 2005 | 02:19 PM
Malgerus's Avatar
It'll be fine!!! As long as that clutch is a 90+ you won't have a problem using it on a Z6 flywheel!
SFlCrx
Apr 19, 2012 08:36 AM
LurkerS8
Texas -OK -LA (Sales)
Feb 8, 2010 07:13 PM
tico
Transmission & Drivetrain
Sep 14, 2008 06:57 PM
DsMWookie
Sep 18, 2002 09:49 PM
