A few ls/vtec Questions...
Old Feb 25, 2005 | 06:50 AM
OMG B16's Avatar
Default A few ls/vtec Questions...
ok well i searched and got SOME info, not all that i need though...
i have a 00 civic si and am considering doing an ls/vtec cause i already have a b16 and most of the componats are already on my car(b16)
ok heres a little list i put together from my search...
B16 head (Have)
B16 tranny (Have)
Golden Eagle LS/Vtec Kit
CTR Cams
ECU
ECU harness
Pistons
Rings
Bearings
New Oil Pump
New Water Pump
LS Complete Shortblock
im wondering if this is all, or if i am missing something?
Modified by Sick00SiCoupe at 1:59 PM 2/25/2005
Old Feb 25, 2005 | 07:50 AM
ea_hatch's Avatar
get arp rod bolts and head studs to
Old Feb 25, 2005 | 07:59 AM
SkRiBLaH's Avatar
Default Re: A few ls/vtec Questions... (Sick00SiCoupe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sick00SiCoupe &raquo;</TD></TR><TR><TD CLASS="quote">ok well i searched and got SOME info, not all that i need though...
B16 head (Have)
B16 tranny (Have)
CTR Cams
Honda coolant
Honda oil filter
ECU
ECU harness
Honda coolant
Honda oil filter
IM gasket
Fuel Filter
LS Complete Shortblock - How muchis this??
im wondering if this is all, or if i am missing something?</TD></TR></TABLE>
your listing all the little **** like coolant (duh)
if you decide to get a LS shortblock (which you can find in the classifieds) then plan on replacing the pistons, rings, adn if they look bad, bearings. also replace water pump and oil pump.
JDM ITR are a good piston choice (need 1mm shaved off each side of each rod's small end in order to fit.)
you basically need to read alot more about what it takes to build a motor
LazJDM
Apr 21, 2006 04:22 PM
1sikhatch
Sep 4, 2005 07:22 AM
jonathan13
13
Aug 23, 2005 12:04 PM
RJH6
Feb 7, 2005 10:02 PM
Methane2k2
Nov 21, 2004 05:45 PM
