Magnaflow exhaust question
Old Feb 25, 2005 | 05:18 AM
93egsi's Avatar
Default Magnaflow exhaust question
I am currently looking for a Magnaflow oval exhaust, I was looking for a Es oval, but they are too expensive for me. I have 2.25 inch piping, and my exhaust is loud as hell right now, and I want to change it. My question is for a civic hatch, which one is a better size to get? 5"x 8", or the 4"x 9"?? I want it to stick out a little bit from the bumper maybe bout an 1" or a 1 1/2". for anyone who has got a es oval or a magnaflow oval, how is the sound?, your input would be greatly appreciated. thanks (and it if its kinda loud, what size resonator should I get? and how much do they run?)
Old Feb 25, 2005 | 06:02 AM
93egsi's Avatar
Default Re: Magnaflow exhaust question (93egsi)
TTT
Old Feb 25, 2005 | 07:26 AM
monicle's Avatar
I have a 3" maganaflow oval muffler. I like the tone. Its fairly low but it does get a little loud when I get on it.
Old Feb 25, 2005 | 07:56 AM
Phantastic's Avatar
Default Re: Magnaflow exhaust question (monicle)
i have a 2.5 magnaflow muffler and it's loud imo even thought i have a cat and big resinator. it's good but i rather have an es oval since it's much more quiet on my friend's car.
Old Feb 25, 2005 | 08:25 AM
93egsi's Avatar
Default Re: Magnaflow exhaust question (Phantastic)
damn so now i'm thinking af gettin the es oval? is there alot of diff in the tone?
Old Feb 25, 2005 | 08:27 AM
VtecAddict96's Avatar
Call up kteller.com they could probably help ya out.
Old Feb 25, 2005 | 08:44 AM
93egsi's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by monicle &raquo;</TD></TR><TR><TD CLASS="quote">I have a 3" maganaflow oval muffler. I like the tone. Its fairly low but it does get a little loud when I get on it. </TD></TR></TABLE>
are you runnin your muffler on a hatch? because im still trying to find out what would be the best size to get?
Old Feb 25, 2005 | 09:02 AM
monicle's Avatar
no mine is on a coupe. Id post a pic but my server is down at the moment for some reason.
Old Feb 25, 2005 | 09:07 AM
93egsi's Avatar
so on your coupe do you have the 4x9 or the 5x8? and about how much does it stick out?
Old Feb 25, 2005 | 09:50 AM
93egsi's Avatar
so can anyone tell me if i should get a 4x9 5x8 for my hatch?
Old Feb 25, 2005 | 10:29 AM
ALX's Avatar
ALX
Default Re: Magnaflow exhaust question (ekdreamer)
what size is the resonator you have now?
Old Feb 25, 2005 | 10:55 AM
monicle's Avatar
5x8 resonated and cat. still as I mentioned a little loud when I get on it but thats with turbo. Probably less dramatic on a stock car. I had a angle cut pipe welded to it so that the sharp side of the cut is inline with the end of the bumper. I dont like pipes that stick out and I like it to be less noticeable.
Old Feb 25, 2005 | 10:56 AM
93egsi's Avatar
Default Re: Magnaflow exhaust question (ALX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ALX &raquo;</TD></TR><TR><TD CLASS="quote">what size is the resonator you have now?</TD></TR></TABLE>
i don't have a resonator on it right now, just my cat, and thats it....to keep the noise down, i was thinking about gettin one though.....either that or just puttin some dynamat in my trunk where the spare tire is to deaden the sound from the inside..... how do you guys think that will work?
Old Feb 25, 2005 | 10:59 AM
93egsi's Avatar
5x8 resonated and cat. still as I mentioned a little loud when I get on it but thats with turbo. Probably less dramatic on a stock car. I had a angle cut pipe welded to it so that the sharp side of the cut is inline with the end of the bumper. I dont like pipes that stick out and I like it to be less noticeable.</TD></TR></TABLE>
nice.......i like how that looks....is that the aluminized one? do they rust fast?, or should i go for the stainless one? im just really lookin for the rust factor.....or i might just get the aluminized one, and paint it with some high heat rustproof flat black spray paint
Old Feb 25, 2005 | 11:06 AM
monicle's Avatar
mine is stainless. I went with a completely stainless exhaust. manifold, downpipe, cat, resonator, muffler, and all pipes inbetween.
Old Feb 25, 2005 | 11:22 AM
EG9 VTi's Avatar
Mine if full stainless steel.
But the one i got is the one you buy directly from them,a full cat-back system.
Old Feb 25, 2005 | 11:40 AM
h22 civic's Avatar
Default Re: (EG9 VTi)
kteller
Old Feb 28, 2005 | 05:38 AM
93egsi's Avatar
Default Re: (h22 civic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by h22 civic &raquo;</TD></TR><TR><TD CLASS="quote">kteller </TD></TR></TABLE>
is that the cheapest place i can but it online?
Old Feb 28, 2005 | 06:28 AM
suspendedHatch's Avatar
Default Re: (93egsi)
I have the Magnaflow alumnized on several of my cars for years now with no rust. If you want it quiet, get the longest muffler that will fit. Get a reasonable diameter for your application. Virtually all NA setups will get more power from a 2 inch diameter. The piping should be 2.25 though cuz they usually measure the OD, while the muffler is measured ID, and the thickness of the pipe makes all the difference. I'm not sure if I remember right, but I believe mine is 11 inches long. Break out the tape measure. I also have a Autozone cherry bomb resonator. My exhaust is quiet with a low tone and it gets all growly when you open it up. No Civic raspiness. People always assume I have a 1.8 liter. I get lots of compliments.
Old Feb 28, 2005 | 08:40 AM
93egsi's Avatar
Default Re: (shaundrake)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shaundrake &raquo;</TD></TR><TR><TD CLASS="quote">I have the Magnaflow alumnized on several of my cars for years now with no rust. If you want it quiet, get the longest muffler that will fit. Get a reasonable diameter for your application. Virtually all NA setups will get more power from a 2 inch diameter. The piping should be 2.25 though cuz they usually measure the OD, while the muffler is measured ID, and the thickness of the pipe makes all the difference. I'm not sure if I remember right, but I believe mine is 11 inches long. Break out the tape measure. I also have a Autozone cherry bomb resonator. My exhaust is quiet with a low tone and it gets all growly when you open it up. No Civic raspiness. People always assume I have a 1.8 liter. I get lots of compliments.</TD></TR></TABLE>
sweet....how much did your resonator cost? and what size resonator did you get?
Old Feb 28, 2005 | 09:20 AM
pucho's Avatar
New User
I have been thinking of getting the 5x8 for my hatch and a 21" resonator. That should make it nice and quiet.
Old Feb 28, 2005 | 09:23 AM
MrHeeltoe's Avatar
My professional opinion....
Magnaflows are the highest performing and most durable muffler out there. All of them have a lifetime guarantee (and yes it includes rusting).
They sound good too. No raspy shittiness when used with a resonator.
Old Feb 28, 2005 | 09:39 AM
getnasty's Avatar
Default Re: (MrHeeltoe)
my car is going in the shop tommorw to get 2.5 all the way bcak with no cat or resonator. how is it gonna sound? loud? and what differance does a resonator make?
Old Feb 28, 2005 | 11:00 AM
93egsi's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MrHeeltoe &raquo;</TD></TR><TR><TD CLASS="quote">My professional opinion....
They sound good too. No raspy shittiness when used with a resonator.</TD></TR></TABLE>
so it will sound raspy when used without a resonator?
Old Feb 28, 2005 | 01:10 PM
ALX's Avatar
ALX
anything without a resonator will be raspy and loud (kazoo). I believe mine is 14", its a magna flow and they go for about 100. My obd-1 EF sound nice and deep, with the baffle in my car its dead quite.
2.5 piping on b16 cat back. generic N-1 muffler
