SRR lower control arms on CRX
Old Feb 25, 2005 | 04:42 AM
B18C1-ED8's Avatar
Default SRR lower control arms on CRX
Just curious as to whether or not the EG SRR LCA's will fit on my 90 CRX HF with little or no modifications?
TIA,
Vic
Old Feb 25, 2005 | 07:31 AM
Outsane's Avatar
Default Re: SRR lower control arms on CRX (B18C1-ED8)
fit no problem..
Many times EG's run 88 LCA's to run type R style shocks.
Old Feb 25, 2005 | 01:14 PM
B18C1-ED8's Avatar
Default Re: SRR lower control arms on CRX (Outsane)
Ok, I'm still kinda confused.
I do know that the 88 CRX shares the same style LCA as the ITR.
To my knowledge virtually everything between the EG & DC are interchangeable.
But my question applies to a 90 CRX HF (I'm not sure how big of a difference this makes). Will I still be able to use the HF shocks on the EG LCA's?
Thanks again,
Victor
Old Feb 25, 2005 | 01:56 PM
PaImportTuner's Avatar
yes you still can. your still using the aftermarket EG style Rear LCA which is like the 89-91 EFs LCA
this is useless info towards what your asking but is true but set you off track:
88 EF LCAs and ITR are same setup and can be used on a EG.
back on track info:
i repeat again, SRR EG rLCA will fit your HF and you will be able to use your 90 HF shocks still. -Nelson
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C1-ED8 &raquo;</TD></TR><TR><TD CLASS="quote">Ok, I'm still kinda confused.
Thanks again,
Victor</TD></TR></TABLE>
Old Feb 25, 2005 | 06:11 PM
B18C1-ED8's Avatar
Default Re: SRR lower control arms on CRX (PaImportTuner)
Thanks, Nelson
Old Mar 11, 2005 | 04:57 PM
ELAMINT5's Avatar
im'ed
VSM EXtasy
May 6, 2005 11:56 PM
AVXHATCH
Dec 2, 2003 05:22 PM
Vp Special K
Nov 18, 2003 12:38 PM
AVXHATCH
Jul 25, 2003 01:42 PM
paulzy
Nov 7, 2001 07:10 PM
