del sol radiator with a prelude h22
im having some problems fitting my manifold and turbo with my radiator and fan. ive seen some h22's with a del sol radiator,on like hatches and coupes, but what about in a lude, any over heating problems?
I had the same problem you have. The best thing for you to do is to purchase a radiator for c&l radiator. You can find them online at coolradiator.com. They will build you a custom radiator to fit your lude. I have an accord with an h22 in it and the radiator they built did the trick. It will cost you about $350- $400. buy the way.. Which manifold do you have? If you dont want to spend that much you can use the del-slow radiator. I've seen it before. I dont know if they had any overheating though. I would protect that motor.
explosive
Nov 1, 2003 07:58 PM
