Your opinion on this DP for my turbo setup....
Old Feb 24, 2005 | 06:56 PM
GEN2TEG's Avatar
Here is a DP a friend of mine made for me. Just wanted general feedback on what you guys thought.
Modified by GEN2TEG at 11:20 PM 2/26/2005
Old Feb 24, 2005 | 06:57 PM
adictionbass's Avatar
Default Re: Your opinion on this DP for my turbo setup.... (GEN2TEG)
i got red x's
Old Feb 24, 2005 | 07:04 PM
GEN2TEG's Avatar
Default Re: Your opinion on this DP for my turbo setup.... (adictionbass)
Links should work now
Old Feb 24, 2005 | 07:06 PM
project dc2's Avatar
nope cant look at them unless we're members
Old Feb 24, 2005 | 07:08 PM
B18C1CYA's Avatar
yup pics no work ,
Old Feb 24, 2005 | 07:10 PM
GEN2TEG's Avatar
Should work now
Old Feb 24, 2005 | 07:12 PM
oxSLEEPERxo's Avatar
Default Re: (GEN2TEG)
red x still, host it on we-todd-did-racining
Old Feb 24, 2005 | 07:14 PM
GEN2TEG's Avatar
Default Re: (oxSLEEPERxo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by oxSLEEPERxo &raquo;</TD></TR><TR><TD CLASS="quote">red x still, host it on we-todd-did-racining</TD></TR></TABLE>
I can see them? Im not sure how to host them through we todd.
Old Feb 24, 2005 | 07:15 PM
GEN2TEG's Avatar
Default Re: (adictionbass)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by adictionbass &raquo;</TD></TR><TR><TD CLASS="quote">
Damn...ill delete the thread...unless someone can help me?
Old Feb 24, 2005 | 07:16 PM
go to we-todd-did-racing.com sing up and upload them there. Like 2 mins.
Old Feb 26, 2005 | 07:20 PM
GEN2TEG's Avatar
Pics now work.....let me know what you guys think.
Old Feb 26, 2005 | 07:31 PM
looks good, got only one concern though, where the dumptube meets the downpipe, it might disturb the flow a bit
Old Feb 26, 2005 | 07:33 PM
GEN2TEG's Avatar
You mean where the dump tube actually meets on the DP?
Old Feb 26, 2005 | 07:40 PM
yea
Old Feb 26, 2005 | 07:50 PM
GEN2TEG's Avatar
Is it bad enough that I should worry, and have another made, or could I go with it?
Old Feb 26, 2005 | 07:55 PM
accordfreak's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GEN2TEG &raquo;</TD></TR><TR><TD CLASS="quote">Is it bad enough that I should worry, and have another made, or could I go with it?</TD></TR></TABLE>
if you're going to route your dump tube back to the downpipe, route it 18" down from the turbo...
Old Feb 26, 2005 | 07:58 PM
GEN2TEG's Avatar
Default Re: (accordfreak)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by accordfreak &raquo;</TD></TR><TR><TD CLASS="quote">
if you're going to route your dump tube back to the downpipe, route it 18" down from the turbo...</TD></TR></TABLE>
So in this case I should have another DP made
Old Feb 26, 2005 | 08:04 PM
DaveF's Avatar
it will be hard to control the boost with the damn thing like that.
Old Feb 26, 2005 | 08:05 PM
id get it all in the car and get it running. It wont be too horribly bad. Just get another one done up when you can. Its not like its going to make anything blow up or break.
Old Feb 26, 2005 | 08:10 PM
GEN2TEG's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by adictionbass &raquo;</TD></TR><TR><TD CLASS="quote">id get it all in the car and get it running. It wont be too horribly bad. Just get another one done up when you can. Its not like its going to make anything blow up or break.</TD></TR></TABLE>
I just thought that the guy making it would have known better. I think I may lobby to have another one made for me. I just don't want to get it in there and then find out it's no good, and creating problems.
Old Feb 26, 2005 | 08:43 PM
Finland's Avatar
looks beautifully designed and built. I'd buy that in a hearbeat.
Old Feb 26, 2005 | 08:44 PM
turboEGhatch's Avatar
That will be fine IMHO. You run into issues when the WG is routed like so.
With a smooth merge like that wastegate, it will cause minimal turbulence and will be ok. When it's at a 90* the gasses try and push in and that causes the turbulence. With the WG routed in like that, parallel to the normal flow of the exhaust gas it should make a smooth transition. Heck, the flow of the downpipe might have some sort of a scavenging effect that makes the WG even more efficient at flowing gas, but I doubt that I say run with it
Old Feb 26, 2005 | 08:45 PM
GEN2TEG's Avatar
Default Re: (Boondock Saint)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boondock Saint &raquo;</TD></TR><TR><TD CLASS="quote">looks beautifully designed and built. I'd buy that in a hearbeat.</TD></TR></TABLE>
Even with the dump tube placed that high? Im trying to determine wether I should keep it or get another one?
Old Feb 26, 2005 | 08:48 PM
boostismycrack's Avatar
E-thug
yeah have him make u a new one and give me that one!
