Quick question about d16z6...
Old Feb 24, 2005 | 03:50 PM
jadugartir's Avatar
Default Quick question about d16z6...
I have a head and block both are d16z6... when i put them together would i want to use a d16z6 head gasket or a d16y8, because they are better metal gaskets? would this even work?
Old Feb 24, 2005 | 03:54 PM
kulangot's Avatar
Default Re: Quick question about d16z6... (jadugartir)
they are the same and the y8 is cheaper....
Old Feb 24, 2005 | 04:05 PM
jadugartir's Avatar
Also Im getting a new tranny. Will i have to use a 88? I know if i swapped the tranny on my stock motor i would need a 88 because of the different number of splines for that year, but does that apply to the new motor?
Iceycrx's Avatar
Default Re: Quick question about d16z6... (sirq2u)
rumor I heard was the Z6 was slightly thinner then the Y8 but Ive never seen anything on paper showing that. Either way it wont make a HUGE differance.
Old Feb 24, 2005 | 04:22 PM
CRX_Control's Avatar
Default Re: Quick question about d16z6... (Iceycrx)
if you have a 88 transmission , use a 88 clutch and fly with it.what kind of tranny are you getting? make sure its from the years 89-91 (cable)
Old Feb 24, 2005 | 04:38 PM
jadugartir's Avatar
Default Re: Quick question about d16z6... (CRX_Control)
I have a d16z6 that im going to swap and im wondering do i have to use the 88 tranny? im gonna buy an si tranny but im not sure if i need to use the 88 or not, since its never going to be hooked up to a 88 engine.
Old Feb 24, 2005 | 04:47 PM
kulangot's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jadugartir &raquo;</TD></TR><TR><TD CLASS="quote">I have a d16z6 that im going to swap and im wondering do i have to use the 88 tranny? im gonna buy an si tranny but im not sure if i need to use the 88 or not, since its never going to be hooked up to a 88 engine. </TD></TR></TABLE>
d16z6, that motor came from 92-95 civic's, not 88
Old Feb 24, 2005 | 04:49 PM
kulangot's Avatar
what motor do you have? is it a d16a6?
Old Feb 24, 2005 | 05:29 PM
jadugartir's Avatar
No no you dont understand. Im swapping in a d16z6. but i have an 88 car. Im gonna buy an si tranny to put on my z6. but what YEAR of si tranny do i need to make it work in my car?
I know that in my 88 DX if i swapped the si tranny right now with a stock engine id have to use a 88 si tranny because of the difference in splines. does that still apply with the z6 motor?
Old Feb 24, 2005 | 06:12 PM
kulangot's Avatar
what clutch are you using? if you are using a 88 clutch then buy a 88-89 si tranny, if your using the d16z6 clutch get a 90-91 tranny...
Old Feb 24, 2005 | 06:21 PM
only the 88s are odd ***** , <TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jadugartir &raquo;</TD></TR><TR><TD CLASS="quote">I have a d16z6 that im going to swap and im wondering do i have to use the 88 tranny? im gonna buy an si tranny but im not sure if i need to use the 88 or not, since its never going to be hooked up to a 88 engine. </TD></TR></TABLE> what year si tranny is it? if it is a 88 then you have to use a 88 clutch/flywheel. If its anything higher then get a 89-91 clutch.
Old Feb 24, 2005 | 06:24 PM
turbo_ef9's Avatar
well heres what i did.. my z6 longblock had a z6 flywheel on it.. i went and bought hydro d-series clutch.. it was easier that way for me.. in order to run a hydro clutch and flyhweel combo, you'll have to use a 90-91 si trans.. imo lots easier if u already have a z6 flywheel..
Old Feb 24, 2005 | 07:40 PM
jadugartir's Avatar
Default Re: Quick question about d16z6... (eli_vang)
sirq2u, I dont have a clutch yet. Or a tranny. Just a d16z6 motor and a 88 dx car.
CRX_Control, I dont have the tranny. Im asking on here what year i will need before i buy one.
eli_vang, My z6 also has a z6 flywheel on it already but its kind of rusted looking... im guessing thats not good... I wasnt aware that you could use any other flywheel? And how would you run a hydro clutch that sounds like a can of worms i dont even want to open... I just want to keep it simple and put a Si tranny on there. Once i know which tranny im gonna use then ill get a clutch for that tranny.
Now, My question is, what year tranny will i need? i guess i couldnt go wrong with 88, since my car is an 88,
but does anyone know if splines matter or not when it comes to motor swaps from a different year altogether? im not sure if the splines difference means where it hooks up to the motor or to what turns the wheels.
Old Feb 24, 2005 | 08:00 PM
Surewin's Avatar
Very simple. Match the year of the transmission with the year of the flywheel and clutch.
If you are going to reuse the flywheel from your '88, get a 88 trans and clutch.
If your Z6 came with a "good" Flywheel use that with a 90-91 clutch and 89-91 trans.
Old Feb 24, 2005 | 08:15 PM
jadugartir's Avatar
Default Re: Quick question about d16z6... (Surewin)
thanks! so z6 flywheel works with 89-91 clutch? thats odd.
The flywheel on mine doesnt look like its in very good shape. I guess ill just keep an eye out for a good tranny/clutch/flywheel combo. Anybody got a good rebuilt Si tranny hit me up
Old Feb 24, 2005 | 09:25 PM
turbo_ef9's Avatar
all dseries match up with each other.. just that 88-89 trannies have different spline count.. if ur going to run the z6 flywheel, just get it resurfaced and run a 92+ clutch and run a 90-91 tranny.. it doesn't matter bout the year of ur car.. just run the z6 motor, z6 flywheel, a 92+ clutch and a 90-91 tranny... you'll be set there..
Old Feb 24, 2005 | 10:30 PM
blackeg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eli_vang &raquo;</TD></TR><TR><TD CLASS="quote">all dseries match up with each other.. just that 88-89 trannies have different spline count.. if ur going to run the z6 flywheel, just get it resurfaced and run a 92+ clutch and run a 90-91 tranny.. it doesn't matter bout the year of ur car.. just run the z6 motor, z6 flywheel, a 92+ clutch and a 90-91 tranny... you'll be set there..</TD></TR></TABLE>
i just learned this a few days ago. too bad i didnt see this post first, would have saved me a good deal of searching
Old Feb 25, 2005 | 02:50 PM
Iceycrx's Avatar
Default Re: Quick question about d16z6... (blackeg)
If your having a hard time with this even though everyone has said the same thing everytime, I would hate to see how you are on the wiring dx to si/vtec whichever you choose to do.
If you have an 88 get flywheel and clutch from 88 and 88 tranny. I would suggest checking out effinmotorworks for trannies for something good
Xxcivic97xX
11
Feb 17, 2017 05:40 PM
ChrisSmilesBack
Jul 24, 2008 12:47 PM
sk3ch
Sep 14, 2006 06:25 PM
hybrid_eg
Feb 19, 2003 08:04 AM
SOcalistreetracer
Jul 10, 2002 12:10 PM
