quick question about blinkers, real weird
need more details.did they used to work and just stopped?do they work when you use the hazard button?do all four signals not work?have you removed the hazard button?
Chris
Chris
where is the turn switch? there were no plugs for some reason when i got the car, i had 2 splice 1s on there, and no hazards dont work, they just stay solid when i put em on, and when i turn em off just 1 stays lit, but they never blink.. i hate electrical ****
hazard switch might be bad. you might also check your fuse for the instrument cluster. I had similar problem. one other thing you have to check as well is your bulbs. make sure that you don't have a one prong light bulb on a socket that needs a dual prong light bulb. that also causes this problem. good luck.....
i dunno, whoever messed wit hte wiring in this car shoudl be shot, im tired of these stupid little problems im having wit this car... all the big **** is fixed and all the little stuff keeps poppin up..... everything works wit hte corners lights except blinkers and hazards.. this mean its hazard switch? do i need 2 take off the whole climate control 2 replace this?
no no, just try and replace the auctual switch its self. in my ef it just pops out with a little pressure from behind the dash.you might have to take out more componets" i dont really remeber my 94 civic all that much"any whoo all you need to do is just unplug it and throq the new one in and see if it fixes your problem. i bet it will.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by black_hatch »</TD></TR><TR><TD CLASS="quote">hazard switch might be bad. you might also check your fuse for the instrument cluster. I had similar problem. one other thing you have to check as well is your bulbs. make sure that you don't have a one prong light bulb on a socket that needs a dual prong light bulb. that also causes this problem. good luck.....
i need dual prong bulbs??? i have single, that really makes a difference?
</TD></TR></TABLE>i need dual prong bulbs??? i have single, that really makes a difference?
Bertsch911
11
Dec 24, 2019 06:01 AM
egboy94
Feb 26, 2011 05:52 AM
soisauce
Nov 6, 2008 03:09 PM
peacexisxfree
Oct 21, 2005 01:06 PM
