help with a rough running crx
Old Feb 24, 2005 | 02:32 PM
erebunicrx's Avatar
Default help with a rough running crx
well i just finished putting in a a6 bottom end on a dx head with dual port still and have a couple questions. the thing idle fine for a few min and then slowly dies. also when you drive it you cant just start off normal you have to lauch at like 4k or it will bog out. it is throwing 2 codes. one id the intake air sensor and the other is the idle air control. do you think thu\si has anything to do with it running like ****? also it smells like gas. thanks for any help
Old Feb 24, 2005 | 02:43 PM
Targa250R's Avatar
be professional
Default Re: help with a rough running crx (erebunicrx)
IACV? Check it. Start re-checking vacuum lines as well, you probably have one hooked up wrong.
Old Feb 24, 2005 | 02:49 PM
erebunicrx's Avatar
yeah its throwing a code for that but will that make it run really bad?or just make a sugeing idle?
Old Feb 24, 2005 | 05:15 PM
erebunicrx's Avatar
anyone have any other ideas?
Old Feb 26, 2005 | 06:24 AM
erebunicrx's Avatar
ttt
Old Feb 26, 2005 | 07:07 AM
dopey88's Avatar
If I remember right the plugs on those two sensors fit the same they could be mixed up (I did that on my ZC swap) But what you should do is check those plugs / check your vac lines / pull your hazard fuse (to reset the ecu) and start it up.
Ralphie
Old Feb 26, 2005 | 10:17 AM
erebunicrx's Avatar
ok thanks i'll try that
michjdm
Mar 29, 2012 08:02 PM
pnoi_boi68
Apr 15, 2010 08:21 AM
716pro
31
Jun 7, 2005 01:31 PM
E-spec Tuner
May 29, 2004 10:30 AM
JALOP B16
Apr 17, 2002 03:31 PM
