What size throttle body for my setup?
before I buy anything I figured I'd ask some pros. What size throttle body should I get?
my set up:
stock b18c1 block
dpr stage 6 headwork
itr cams
hondata s200
dc jdm 4-1 header
2.5" cat
rsr cat back
skunk 2 IM
I figure my compression is somewhere in the low 11's, I'd like to make somewhere in the 190-200 whp range. I know the inlet of my skunk 2 IM is 64mm, so should I get my stock gsr throttle body bored to 64 mm, or would there be a better option. Any reason to go bigger then 64mm?
Thanks
my set up:
stock b18c1 block
itr cams
hondata s200
dc jdm 4-1 header
2.5" cat
rsr cat back
skunk 2 IM
Thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DarkSolPR »</TD></TR><TR><TD CLASS="quote">stock comp. stick with the 64mm if you raise your comp. and put big cams you can go up to 70mm</TD></TR></TABLE>
the compression really has nothing to do with the amout of air being drawn into the engine with the stuff you listed i would get the biggest you can find as long the price is in reason
compression is not stock, dpr stage 6 headwork has rewelded combustion chambers. My compression is somewhere in the low 11's. Why go bigger than a 64mm throttle body when the inlet of the skunk 2 IM is 64mm? What is the advantage?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by foot »</TD></TR><TR><TD CLASS="quote">You could always port match the IM. Try Maxbore.com if you were considering boring out your stock TB.</TD></TR></TABLE>
That's what I was planning on doing. Does port matching the tb just mean aligning it exactely with the inlet of the IM? is this necessary if I have a 64mm TB and a 64mm inlet on my IM?
If you get a TB that is larger that the inlet on your IM then you can just dremel off the excess material. If you are using a TB that is the same diameter as the IM inlet than it isn't really necessary. However, I have seen some people port the IM inlet anyway to maximize flow. I would think this would require some experience, more than I have anyway. You may want to get more information from some experienced porters.
