Posted in Tech, but maybe this will work better. Skunk2 VS. GSR manifold
Old Jan 19, 2002 | 11:47 PM
B18C-EJ1
Guest
Posts: n/a
Default Posted in Tech, but maybe this will work better. Skunk2 VS. GSR manifold
Does anyone have a dyno plot before and after install?
I'd like to really know if the S2 IM makes a major difference over the stock unit.
I've been considering going back to the GSR IM for the added torque in the low end.
Thanks.
Old Jan 20, 2002 | 08:13 AM
stick's Avatar
Default Re: Posted in Tech, but maybe this will work better. Skunk2 VS. GSR manifold (B18C-EJ1)
i can do it for you but ill have to scan the dyno plots
just remind me thru IM in a few days
Old Jan 20, 2002 | 09:16 AM
Dirty GS-R's Avatar
New User
Does it feel like you lost a lot of low end? What other mods do you have?
Old Jan 20, 2002 | 10:13 AM
Evil DOHC's Avatar
Default Re: Posted in Tech, but maybe this will work better. Skunk2 VS. GSR manifold (2K1 GS-R)
Personally I think Skunk2 is all hype. If you use the old muscle car theories you can make the stock GS-R manifold work very nicely for you (hint).
EVIL
Old Jan 20, 2002 | 11:24 AM
alexboy's Avatar
Default Re: Posted in Tech, but maybe this will work better. Skunk2 VS. GSR manifold (Evil GS-R)
Stock for stock honestly i would say stay with the gsr manifold. The s2im on a stock gsr loses a noticable amount of mid range and gives back a few ponies up top. Personally not worth the money or install time if you are not planning to mod past i/h/e. Also with the gsr's low vtec crossover it should be raised to abou 4800 -5100 rpm
Old Jan 20, 2002 | 12:10 PM
C-speed's Avatar
Default Re: Posted in Tech, but maybe this will work better. Skunk2 VS. GSR manifold (alexboy)
red = skunk2
blue = GSR
no other changes (other than tuning of course)
Old Jan 20, 2002 | 01:13 PM
B18C-EJ1
Guest
Posts: n/a
Default Re: Posted in Tech, but maybe this will work better. Skunk2 VS. GSR manifold (G3-TEG)
G3 - Is your GSR turbo'd?
Thanks for the plot.
Old Jan 20, 2002 | 01:16 PM
C-speed's Avatar
it used to be:
http://www.c-speedracing.com/integra.html
tomlinson619
May 22, 2006 06:56 PM
tomlinson619
Apr 14, 2006 04:26 PM
THE94GSR
May 13, 2004 08:04 AM
Halo
Jan 5, 2003 09:43 PM
B18C-EJ1
Jan 20, 2002 04:24 PM
