Will the Integra Comptech sway/tie combo bolt on to a Del Sol???
Old Feb 24, 2005 | 12:33 PM
Bryro22's Avatar
Default Will the Integra Comptech sway/tie combo bolt on to a Del Sol???
Searched and found nothing about the Comptech sway/tie combo fitting on a Del Sol. I know it will fit on the 92-95 civics with integra lca's and since the 93-97 del sols, 92-95 civics, and 94 up integras have interchangeable suspension components, I would assume the Integra Comptech sway/tie bar combo will bolt up on a Del Sol. Can someone assure me on this please?!?!
My other questions are:
Will any aftermarket LCA's work with the Comptech sway/tie combo? (in other words, do i have to buy integra LCA's or can i go with aftermarket ones?)
Are the holes drilled for the sway bar in the stock integra LCA's the only difference compared to the 92-95 civic/93-97 del sol LCA's?
Is there anything else i need to know besides needing a nut and lockwasher on the subframe? (That is, if the Del Sol needs them, as do the 92-95 civics.)
Any information will help. Thanks
Old Feb 24, 2005 | 01:12 PM
Bryro22's Avatar
Default Re: Will the Integra Comptech sway/tie combo bolt on to a Del Sol??? (Bryro22)
Bump!
Old Feb 24, 2005 | 01:25 PM
Bryro22's Avatar
Anybody willing to help me out here? pleassssse.....lol. Maybe if i keep begging.
Old Feb 24, 2005 | 01:52 PM
Bryro22's Avatar
bump, need this answered!
Old Feb 24, 2005 | 01:59 PM
Lee_Delso's Avatar
From what I know the del sol vtec model shares alot of the gsr suspension so my guess would be that it should fit. But you better get a second opinion.
Old Feb 24, 2005 | 04:04 PM
GS8HFL21's Avatar
Default Re: Will the Integra Comptech sway/tie combo bolt on to a Del Sol??? (Lee_Delso)
ok here we go>:
The comptech sway bar/tie bar combo WILL fit on the del sol. i have one on mine..i love it. you need to get different rear lca's providing u dont have a dohc sol. aftermarket lca's keep the factory location for the endlink mounts for the sway bar so they will work too. HOWEVER aftermarket lcas have two down falls (ususally)1. poor bushing quality and 2. extra negative camber. They look sick as hell though
The intagra lca's i have the holes drilled in them and i believe also have the screws to mount up the abs lines, which u wont need any way.
if you are buying a kit from comptech or whatever itll come with brackets that screw right into the lcas and then their endlinks screw into them. Different set up as far as mounting goes with the stock one but same location. Hope this helps. any other questions let me know man.
Old Feb 25, 2005 | 05:44 AM
GS8HFL21's Avatar
btw im not sure if the part numbers are the same...but i think everything under the car is..(measurements) i have a tie bar/sway bar from an integra on mine.
jackiechan
Mar 15, 2007 07:44 PM
Mikizzle
Northwest (Sales)
Aug 16, 2006 11:23 AM
idriveadelsol7
Suspension & Brakes
Sep 20, 2005 09:02 AM
idriveadelsol7
Apr 13, 2005 09:25 PM
Bryro22
Feb 24, 2005 12:20 PM
