Top Mount Manifold.......All Hype or Not
Old Feb 24, 2005 | 09:44 AM
cnydc2's Avatar
Default Top Mount Manifold.......All Hype or Not
I am looking at puting together a new setup. I am in the middle of researching different manifolds to use. I've searched many times and have found that many people are saying that the top mount is just a new H-T bandwagon. I am just looking for input on whether the top mount shows improvments over the other manifold. I am trying to decide whether I should pursue the top mount or should go with a more conventional manifold like the Full Race Prostreet or the One Fab Type One.
Any help on this would be great, I just don't want to spend the money on the top mount if it isn't any better than any of the other manifold.
Old Feb 24, 2005 | 09:49 AM
TurboJesse
Guest
Posts: n/a
Default Re: Top Mount Manifold.......All Hype or Not (cnydc2)
I use a top mount manfold, to me the main benifits were ease of removing/intsalling turbo, Removing/installing DP, Oil return is very direct and don't ahve to worry about kinks or low hanging turbo. Looks sick too
Old Feb 24, 2005 | 10:01 AM
m R g S r's Avatar
Default Re: Top Mount Manifold.......All Hype or Not (Mpir3)
Don't you have the sidewinder?
Old Feb 24, 2005 | 11:11 AM
beepy's Avatar
I have a top-mount, and did it before top-mounts were "popular".
My reasoning was room. I can fit a T3 with internal wastegate in the car without having to touch the radiator. Other benefits include easy access to the turbo, all the hoses stay away from the exhaust, and the oil drain is nearly straight.
The downside is a more circuitous downpipe.
Old Feb 24, 2005 | 11:23 AM
Luke J's Avatar
Default Re: Top Mount Manifold.......All Hype or Not (beepy)
Definitely all hype................
-you should stick with the SS autochrome.
Old Feb 24, 2005 | 11:30 AM
Full-Race Geoff's Avatar
the biggest advantages are that it is easy to acces your turbo, the design is such that there is equal pressure at the turbine flange, and the equal pressure is coupled with proper cylinder pairing. We have made excellent gains thus far on the track with this setup.
btw i dont see any downside to the downpipe, only an upside as you can now run a 4" downpipe on the street, something that DOES make a difference on larger turbos
if you have any questions feel free to email me at geoff@full-race.com
Old Feb 24, 2005 | 11:59 AM
cnydc2's Avatar
Default Re: Top Mount Manifold.......All Hype or Not (Full-Race Geoff)
Thanks Geoff, happy to attract a big name. Any more info would be great. I may attempt to try to make one myself for a welding class project, but if I come accross enough money I want the Full Race setup hands down.
Once again, Thanks for the Advice. If anyone else has any info on this please let me know.
Old Feb 24, 2005 | 12:03 PM
Burke's Avatar
Banned
i can think of one disadvantage. higher center of gravity, which we all know is not a good thing for handling purposes
Old Feb 24, 2005 | 12:11 PM
turbosi03's Avatar
Default Re: Top Mount Manifold.......All Hype or Not (Burke)
I'm guessing you would get higher under hood temps with this setup... does anyone know this to be true? ruff percentage increase?
Old Feb 24, 2005 | 12:44 PM
cnydc2's Avatar
Default Re: Top Mount Manifold.......All Hype or Not (turbosi03)
I've read that the top mount doesn't show any extra under hood temp increases. The reason for this is that the manifold piping is under the turbo and is better cooled by incoming air. I could be wrong but I'm pretty sure I read that some where on H-T when I was searching, feel free to correct me if I'm wrong.
Old Feb 24, 2005 | 02:17 PM
trickeng's Avatar
and why would anyone ever think that top mount or bottom would alter under hood temp???
think about it. they are similar high flow manifolds and they are both UNDER THE HOOD IN THE SAME GENERAL LOCATION!!!
if you were compairing the radiant heat of a log style manifold vs. a full-race then you would see that the log radiated much more heat.
more HP creates more heat. so when someone go's from a stock low hp application to a built high hp application the engine/turbo/manifold ect.. will give off more radiant heat and cause under hood temps to go up.
as for your initial q about hype. look at what those manifolds are helping people produce for HP which a lot of people on this site have shown via dyno sheets or video, so i would like to see how bad the guy gets flamed who tries to claim it as being hype.
Full-Race has it going on and i push there products any chance i get.
Old Feb 24, 2005 | 02:34 PM
honda9krpm's Avatar
The only disadvantage is the fact that the exhaust turbine is closer to the bonnet and the top of the engine. Without appropriate measure you may cause heat damage to the bonnet and other engine component.
I only use a simple heat shield with my top mount turbo and have done some temperature logs. The temperature near the turbo is slightly higher than the temperature behind the radiator but by only a few degrees. As long as you can control the radiant heat you will be ok IMHO.
IMHO some of the advantages for a top mounts are
-looks a lot better
-better oil flow
-you can fit a larger turbo
-shorter air intake pipe, may gives better throttle response
Old Feb 24, 2005 | 02:44 PM
D-tuned's Avatar
Default Re: (honda9krpm)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by honda9krpm &raquo;</TD></TR><TR><TD CLASS="quote">The only disadvantage is the fact that the exhaust turbine is closer to the bonnet and the top of the engine. Without appropriate measure you may cause heat damage to the bonnet and other engine component.
-looks a lot better
-better oil flow
that S2K is sexy
Old Feb 24, 2005 | 03:37 PM
CRXDrew's Avatar
Default Re: (2000civicsi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2000civicsi &raquo;</TD></TR><TR><TD CLASS="quote">that S2K is sexy </TD></TR></TABLE>
Uh huh... and w/ 8 posts under his belt. We need more low number/nice car posters in the CRX/EF forum
Old Feb 24, 2005 | 03:51 PM
cnydc2's Avatar
Thanks for the reply. Your engine bay looks great. Like to see more pics of the whole car
Old Feb 24, 2005 | 05:34 PM
turbosi03's Avatar
Default Re: (cnydc2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by trickeng &raquo;</TD></TR><TR><TD CLASS="quote">and why would anyone ever think that top mount or bottom would alter under hood temp???
here's why I questioned... the DP has more lenght in the eng bay, thats more radiated heat... the turbo is no longer getting as much fresh air to help cool, and we all know the turbine snail gets damn hot... although good point about the runners being in the spot where the turbo would be on the old style, so that probably gets cooler...
just a few reasons to get your wheels turning
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by trickeng &raquo;</TD></TR><TR><TD CLASS="quote">if you were compairing the radiant heat of a log style manifold vs. a full-race then you would see that the log radiated much more heat.
I can't say your wrong, but do you have or know where I can find proof of this? I was under the impression that the log mani's radiated less heat because the runners are shorter, thats less hot pipes radiating heat..?
Old Feb 24, 2005 | 06:57 PM
gldndrgn14's Avatar
edit.. my bad, read it wrong, thought it said top mount intercooler. haha
Old Feb 24, 2005 | 07:17 PM
stealthmode62's Avatar
Default Re: Top Mount Manifold.......All Hype or Not (gldndrgn14)
I haven't seen a top mount installed, but the oil drain line should be a hell of a lot better, and the downpipe should be easier to mount/use larger pipe as well. Both good things.
Old Feb 25, 2005 | 10:32 AM
Default Re: Top Mount Manifold.......All Hype or Not (stealthmode62)
here is a pic of my personal civic's engine bay
Old Feb 25, 2005 | 10:44 AM
FOrSfEd's Avatar
Geoff not a pink valve cover lol j/k
Old Feb 25, 2005 | 10:54 AM
paulzy's Avatar
pink/salmon is out bro...gotta stripe your valve coverf and block now...lolz
As far as the manifold. the top mount would be a great way if you want more room for a larger turbo, more incline for the oil return line, and a much larger downpipe
Old Feb 25, 2005 | 10:59 AM
*Boostwerks*'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Full-Race Geoff &raquo;</TD></TR><TR><TD CLASS="quote">here is a pic of my personal civic's engine bay
Ahhh...even your engine block is pink!
That GT40 can't even make up for the fact your running a pink block.
...***. hehe.
Old Feb 25, 2005 | 11:00 AM
ShaunRR's Avatar
HT White Ops
Community Builder
Geoff is an emo punk
Old Feb 25, 2005 | 01:37 PM
sleeprhatch's Avatar
Default Re: Top Mount Manifold.......All Hype or Not (rochesterricer)
stinky pinky valve cover
Old Feb 25, 2005 | 02:35 PM
cnydc2's Avatar
That looks great!! Do you have any power #'s or care to share your specs?
BTW isn't that intake manifold still a prototype?!?!?!?
