JDM 4th Gen Climate control
Old Feb 24, 2005 | 09:00 AM
tdo's Avatar
tdo
Default JDM 4th Gen Climate control
well I finally got all the parts needed to install this.
lets see if I go insane trying to install it.
*edit* using this site to help --> http://www.jrcormier.com/prelu...l.php
*EDIT* - on that site there is one wire that jrcormier doesnt show you how to connect, so ill show you on here. The #1 blu/yel wire on the JDM 20 pin connects to the blu/yel wire for the a/c pressure switch. remember the thermostat plug? well its the blu/yel wire on that plug. just connect it to the #1 blu/yel wore on the JDM 20 pin.
Day1
2 Hours in.... LUNCH BREAK !
well couple more hours gone by and i installed some sensors, took out blower unit, drain radiator (big mess ), took out evaporator, and now im having troubles taking out the 2 hoses that connects to the heater unit .... those got damn things wont come out.
any one know a easy way to take out those 2 hoses? im having trouble pulling it out.
Day2
well after running into the hoses problem i just cut them, but now i got another problem. I need a relay.
heater hoses stll wont come out!
the end of day 2 ... i got the hoses off, i just had to introduce them to Mr. Razor Blade
Well now that the heater hoses out the way i finally got some stuff done.
SHES ALIVE !
Heres a small video from my digi cam of the mix motor. ( if it dont work then right click save as )
Day 3
Made this for the air mix motor
with everything back on
***EDIT*** - (place where i mounted the air mix motor) the air mix motor will move when its in place. You should try to screw a second screw in somewhere. and you will have to cut a little bit of the center console if you put that in the same location i did.
Wired everything
TA DOW !!
now i just need to put the heater hoses back on then the dash and im DONE !!!
took 3 days but its worth it. Would of been 2 days, but the heater hoses gave me a hard time.
Hey you 5th Gen guys look ---> JDM climate control for BB6!!
Day 4
DONE !!!
WOOO HOOO !
Modified by tdo at 8:08 AM 4/11/2005
Old Feb 24, 2005 | 09:20 AM
9deuce9rr's Avatar
Default Re: JDM 4th Gen Climate control (tdo)
good luck man... let us kno how much of a pain in the *** it is cuz i'm thinkin about doin it this upcoming summer
Old Feb 24, 2005 | 11:28 AM
NeriVTEC's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WhiteLude &raquo;</TD></TR><TR><TD CLASS="quote">good luck man... let us kno how much of a pain in the *** it is cuz i'm thinkin about doin it this upcoming summer </TD></TR></TABLE>
Yeah please let us know because I also am planning to do this very soon.
Old Feb 24, 2005 | 11:39 AM
vtecludeh22's Avatar
Default Re: (NeriVTEC)
my freind in az here did one and it works fully. good luck
Old Feb 24, 2005 | 12:17 PM
mesh's Avatar
Default Re: (vtecludeh22)
hey man, pm me who your friend is, I was looking to do this, but I havent met anyone in az that works on preludes, I would be willing to pay to have this converted over....
Old Feb 24, 2005 | 12:36 PM
wstef's Avatar
Good luck !! !!! !!!!
Old Feb 24, 2005 | 12:41 PM
LudeBehavi0r's Avatar
Holy $#*^ that looks like chaos, good luck with it man.
Old Feb 24, 2005 | 01:28 PM
92LudeSI's Avatar
Looks good! I noticed you have some wires running around in your drivers side tweeter cover. Is this somthing for the fog lights? Im trying to figure out what wire does what if you know hit me up with a pm!
Old Feb 24, 2005 | 01:33 PM
The Phil's Avatar
have fun with that, i've been wanting to do that for awhile.
Old Feb 24, 2005 | 02:53 PM
h22mark's Avatar
Well if anyone wants the main control unit I have it with cut wires but I'll let it go for dirt cheap don't need it in a race car, all you gotta do is pay for some shipping.
Old Feb 24, 2005 | 06:21 PM
Default Re: (h22mark)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mesh &raquo;</TD></TR><TR><TD CLASS="quote">hey man, pm me who your friend is, I was looking to do this, but I havent met anyone in az that works on preludes, I would be willing to pay to have this converted over....</TD></TR></TABLE>
ill have to talk to him to see if he would want to do that and/or if he has the time. are u on the azpreludes forum?
Old Feb 24, 2005 | 06:26 PM
tdo's Avatar
tdo
i thought i was going to do it in one day, but guess not. everything went smooth till i got to the heater unit. Those 2 hoses that carry coolant through the firewall to the heater unit wont come off . Im going do that later since i cant put out the hoses. Im going to wire everything up then try that again.
Old Feb 25, 2005 | 04:31 PM
tdo's Avatar
tdo
Default Re: (tdo)
well after cutting the hoses it sill wont come out .... has anyone ever changed the heater hoses before? cuz this thing is a pain in the ***. these 2 heater hoses is slowing me down.
i got everything wired and done. just need to get that heater hoses out and install air mix motor and im done.
Old Feb 25, 2005 | 06:57 PM
skrewdlude's Avatar
Default Re: (tdo)
I changed them once when one blew up. They are apin to get out cuase the thing they attach ti flexes when you pull on the hose.
I ended up spending a lot of time with a utility knife to get them off
Good luck man
Old Feb 25, 2005 | 07:17 PM
tdo's Avatar
tdo
Default Re: (skrewdlude)
HOLY JABEEEBUS !! Its a miracle !
And here are the bitches that took forever !
EDIT !!
if your a/c & heater works fine then dont go with the JDM climate control.
My climate control was messed up and one of my heater hoses was busted so i decided to upgrade to the JDM climate control. If you still want to do it, then go for it. I think its worth it.
I did it because i love my lude.
Old Feb 26, 2005 | 08:23 AM
tdo's Avatar
tdo
Default Re: (tdo)
ALL MOST DONE !!
soooo tired....
Old Feb 26, 2005 | 10:02 AM
Siegfried's Avatar
Default Re: (tdo)
Did you have to make a support for the Air mix motor ?
Oh and could you put pics of where you install your sensors.
Old Feb 26, 2005 | 11:03 AM
pentaq's Avatar
Default Re: (Siegfried)
All I want to say is: digi climate control rulezz. I drove today a JDM Prelude with it and it's marvellous. But driving RHD car in a LHD country sucks a lot
Old Feb 26, 2005 | 12:15 PM
fastludeh22's Avatar
Default Re: (pentaq)
funny i was going to do this on thursday also...but my car was stuck in my friends yard. (its on a trailer, and his yard was a mudhole)
thinking about starting on it
Old Feb 26, 2005 | 03:23 PM
forgotmypassword!(OTT)'s Avatar
JDM Climate Control is worth the effort.
Old Feb 26, 2005 | 03:52 PM
tdo's Avatar
tdo
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Siegfried &raquo;</TD></TR><TR><TD CLASS="quote">Did you have to make a support for the Air mix motor ?
Oh and could you put pics of where you install your sensors.</TD></TR></TABLE>
the bracket came with it. I installed the outside temp near the vent things on the ludes, sun light near the windshield on passenger side, in car temp between the steering wheel and the climate control, and the evaporator sensor in the evaporator where the thermostat uses to be.
hope that helps.
SUN LIGHT SENSOR
OUTSIDE SENSOR
EVAPORATOR SENSOR
IN-CAR SENSOR
its so cold, i dont know if i want to finish up my car.
Old Feb 26, 2005 | 03:55 PM
djbrandonr's Avatar
Default Re: (tdo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tdo &raquo;</TD></TR><TR><TD CLASS="quote">if your a/c & heater works fine then dont go with the JDM climate control.
so are you saying ac and heat wont work if you do the mod??
Old Feb 26, 2005 | 04:01 PM
tdo's Avatar
tdo
Default Re: (djbrandonr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by djbrandonr &raquo;</TD></TR><TR><TD CLASS="quote">
so are you saying ac and heat wont work if you do the mod??</TD></TR></TABLE>
no i mean if it works fine now (stock one). Because its a lot of work.
I thoguht it went pretty smooth untill i got to the heater hoses. I hate those things, they took me 2 days just to get them off. Now i have to buy 3 hoses for the heater. well one of them was busted i have to replace it anyways, the other 2 was getting kind of old so minus well i guess.
Old Feb 26, 2005 | 08:11 PM
Siegfried's Avatar
Default Re: (tdo)
Thanks for the sensor pics
Did you use the Blower Motor High Relay or another relay ?
Old Feb 26, 2005 | 08:46 PM
tdo's Avatar
tdo
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Siegfried &raquo;</TD></TR><TR><TD CLASS="quote">Thanks for the sensor pics
the guy i bought it from didnt give me a relay. So i went to auto zone and got one because and the junk yards were closed. I just picked up a relay for some fog lights. Works fine. If you want go to a junk yard, hondas have relays all over the place. for lights, power window, sun roof, abs, etc. theres like 4 in the fuse box under the hood.
just make sure its a 4 pin relay.
