NRG engine damper
Old Feb 24, 2005 | 08:46 AM
truesleeper's Avatar
Default NRG engine damper
I ordered one of those NRG engine dampers the other day. It says it mounts between the block and the firewall. I havent got it yet but has anyone installed one of these and how hard is it to put one in, i cant think of where it would go but i havent really looked. Anyone?
Old Feb 24, 2005 | 09:18 AM
boonacka's Avatar
Default Re: NRG engine damper (truesleeper)
do they make one for the accord? whered you get it?
Old Feb 26, 2005 | 11:56 AM
Default Re: NRG engine damper (boonacka)
istoreparts.com has them advertised for 94-00 accords. They are made by NRG
Old May 21, 2006 | 09:07 AM
2slowCivic's Avatar
where can i find one for a 91lx???
Old May 21, 2006 | 09:20 AM
mattf22b1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boonacka &raquo;</TD></TR><TR><TD CLASS="quote">do they make one for the accord? whered you get it?</TD></TR></TABLE>
yes they make them for accords nrg makes them for 94-02 accords both 2 and 4dr and with either the 4 cylinder or 6. http://www.tasauto.com has them for $100...it says on http://www.istoreparts.com that you can only use the damper if you car is dohc. This doesn't matter as the mounting bracket is universal
Old May 21, 2006 | 03:48 PM
krispyaccord's Avatar
what purpose do these serve....less wheel hop? similar to upgraded motor mounts? Thanks for the help...
Chris
Old May 21, 2006 | 05:11 PM
importfanatic17's Avatar
Default Re: (krispyaccord)
They supposedly keep your engine from lurching back on launch/gear shifting. "They" claim that it makes a HUGE difference.
Old May 21, 2006 | 07:01 PM
mattf22b1's Avatar
Default Re: (importfanatic17)
Increase engine stability
Reduces wear on factory mounts
Reduce torque loss from excessive engine movement
If you get polyurethane motor mount inserts as well this can be a great set-up
DeDonDeRosa
11
Oct 14, 2005 07:11 PM
paxorion
Feb 25, 2005 03:31 AM
insane123
Mar 5, 2004 05:58 PM
StatikPhreeze
Jan 11, 2004 06:47 PM
RobertMcDonald
Jun 5, 2003 07:13 AM
