b18c question? need an answer a.s.a.p.
which motor is better besides the horse power of course and maybe a couple of little things
the b18c jdm gsr or the b18c jdm type r (96)?
this is what i got with the type r i kept it obd1 so im running a p28 ecu chipped out,got stage 2 competition clutch,aem fuel rail aem fuel regulator,walbro 255 fuel pump,msd, and everything else stock,
now with the gsr first of all is clean as fu(**& i got light weight flywheel stage 3 competition clutch lsd tranny aem fuel rail aem regulator ,msd ,walbro 255 pump,and skunk2 pro +1 cams in it,and v-afc2
now being realistic which one would you guys get onestly?
i need an answer by today...
Demanding aren't you? Well imo I would chose the type uuurrhhh over a gsr anyday but if you're on a budget then I would go with the gsr.
i got the gsr it was cheaper and another thing i didnt know all the internals are type r so i should be ok,the type r i had to order the gsr was there already and is clean clean clean! is one of the cleanest engine ive seen.
thanks!
p.s. of course type r is better but the gsr was wayyyyy cheaper and basicly got almost the same thing all type r internals so its kool plus the ecu (p72) is chipped out
thanks!
rickkane
Jul 30, 2008 10:43 PM
