Water leaks into my hatch when it rains
Old Feb 24, 2005 | 04:48 AM
Cuong-nutz's Avatar
Default Water leaks into my hatch when it rains
I just got back from driving around in the rain. I noticed a pool of water in the back of my hatch. Did a little investigating and I noticed it's coming from the rear passenger tail light and also the strut mount area. Went outside and also noticed that my passenger tail light is full of water. Could it possibly be a bad tail light gasket? Where can I get another tail light gasket? How can I fix the leak coming from the strut hole?
Old Feb 24, 2005 | 04:50 AM
Ricey McRicerton's Avatar
Default Re: Water leaks into my hatch when it rains (Cuong-nutz)
Yes, it could. Check to see if the light is still tight, and if it is, replace the gasket. This is very common.
Old Feb 24, 2005 | 05:05 AM
Cuong-nutz's Avatar
Default Re: Water leaks into my hatch when it rains (Ricey McRicerton)
Yep... time for a new gasket
Old Feb 24, 2005 | 05:06 AM
RiceInspiredFireFighter's Avatar
Could be the tail light grease
Old Feb 24, 2005 | 05:16 AM
SniperRCivic's Avatar
if you have had this problem for a while you might as well just replace the light and the gasket you might have lost some of the chrominess of the light and it wont be as bright..as for where if your on a budget try a junk yard or maybe even ebay if not HONDA
nabs.no.abs
Apr 8, 2014 09:32 AM
Spawne32
Jul 2, 2009 12:17 PM
sil04ver
Nov 18, 2008 06:35 AM
TehMoonRulz
22
Apr 22, 2006 04:16 PM
