Boost Gauge In Hand. Something not right? *PICS*
Old Feb 24, 2005 | 01:39 AM
W O T's Avatar
Default Boost Gauge In Hand. Something not right? *PICS*
Got my cheap boost gauge today, its a Faze gauge
I notieced that the vacuum line it uses is *** small though, like 4mm OUTER dieameter and I dont even know what I can connect it to that small, definetely not my DIY vacuum manifold
Heres a pic of the line next to my hand, totally small and the weird fitting
Pic of the back
And for ****, heres me blowing into the end making a whopping 1.5psi of boost lol, must be the cake I ate
Now what I wanna do is just take some fairly nice 5/16" inner diameter hose from work which will clamp on my vacuum mani just fine and then just take the fitting off of the back of the unit and put the vacuum line right over the threads of where the fitting ataches to..... work fine?
I dunno, thanks for peepin the blurry pics
Old Feb 24, 2005 | 01:56 AM
BoOsTiN Dc2's Avatar
Default Re: Boost Gauge In Hand. Something not right? *PICS* (W O T)
u can just take that puny *** line and put it in a vacuum hose and use zip ties.
Old Feb 24, 2005 | 02:01 AM
Frozen E's Avatar
H-T White Ops
My autometer gauge came with a vinyl line like that. Nothing wrong with it. You can get rubber adapters that go from that tiny line to a 5/16" connector. I've seen them at parts stores. The autometer actually came with one.
Old Feb 24, 2005 | 02:05 AM
W O T's Avatar
Default Re: (IslandSi)
Just thought of this, what if I cut off the end end of the vinyl line, stick it in a rubber hose, clamp that end, and continue to run my rubber to the vacuum manifold...
I dunno, this line is dam thin
Old Feb 24, 2005 | 02:14 AM
Default Re: (W O T)
thats what i meant... take the line on the boost guage and stick it into the vacuum hose and use zip ties... make sure its tite though
Old Feb 24, 2005 | 02:58 AM
BoostedCivicSedan's Avatar
Default Re: (tRaCeBuStAbUsTeR)
You can go buy brass fittings at home depot to run that to your vacuum manifold... Im doing the same thing with mine...
Old Feb 24, 2005 | 03:51 AM
junkyard racer's Avatar
Default Re: (BoostedCivicSedan)
I wish i had more pictures of mine, but this is what I did. (pretty much what everyone else has said) but i bought some vaccumm line and it fit on there tightly, but i still ran a zip tie around it to make it seal. so far, no problems.
Old Feb 24, 2005 | 04:05 AM
BlueShadow's Avatar
Here is a close up pic of the parts you will need:
http://static.summitracing.com...3.jpg
You use the two fittings and the little ferrule on the end of your nylon hose. Then you screw in a barbed fitting onto the end of the ferrule/fittings. Then you just put your vacuum line from the IM and plug it into the barbed fitting
If you can find the ferrule/fittings at your local hardware store you can order it from http://www.summitracing.com Part number ATM-3223 for the one with the 6ft nylon hose and ATM-3226 has the 12ft nylon hose. If you order either kit from summit it will only be about $10-$15.
EDIT: here is how my stuff is gonna be set up. The nylon hose is gonna go from the gauge/pod then through the firewall to the engine bay where I will hook it up like in my pic below. Then the other end of the blue vacuum hose will go to my GE vacuum manifold. You might be able to find all the fittings and ferrules at your local hardware store. Just bring the nylon hose so you can make sure the ferrule fits over it (thats the small brass thing on the hose).
Modified by BlueShadow at 5:20 AM 2/24/2005
Old Feb 24, 2005 | 04:25 AM
USDM 4G VTEC's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tRaCeBuStAbUsTeR &raquo;</TD></TR><TR><TD CLASS="quote">thats what i meant... take the line on the boost guage and stick it into the vacuum hose and use zip ties... make sure its tite though</TD></TR></TABLE>
i just have mine just pushed into the vacum line
and its being over 10 mths boosting 10 psi and it hasnt come off yet
Old Feb 24, 2005 | 04:39 AM
turboteg2nv's Avatar
Default Re: Boost Gauge In Hand. Something not right? *PICS* (BlueShadow)
I think I'm with BlueShadow on this one, that's a clean setup. Then again..if I get lazy I might just go with USDM 4G VTEC's plan, use a little glue/sealant and call it a day.
***And damnit, put on the MACRO function on your P.O.S. digi cam so you stop making my eyes hurt trying to see these noncoherent pictures. damn
Old Feb 24, 2005 | 04:42 AM
BlueShadow's Avatar
Default Re: Boost Gauge In Hand. Something not right? *PICS* (turboteg2nv)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turboteg2nv &raquo;</TD></TR><TR><TD CLASS="quote">I think I'm with BlueShadow on this one, that's a clean setup. Then again..if I get lazy I might just go with USDM 4G VTEC's plan, use a little glue/sealant and call it a day.</TD></TR></TABLE>
Yah, you have to be careful with the nylon hose because you cant bend or kink it otherwise it could throw off your readings.
Old Feb 24, 2005 | 05:49 AM
PM-Performance's Avatar
Default Re: (USDM 4G VTEC)
you guys are making this harder then it is. Take off the compression fitting and just put a like 6mm vac line on it and zip tie it and call it a day. ive done it plenty of times with no issues..
Old Feb 24, 2005 | 07:09 AM
m R g S r's Avatar
Default Re: (itr206)
Or do what I did. . .
Tapped the back of the IM. .
Old Feb 24, 2005 | 07:17 AM
SOHC_MShue's Avatar
i just took the vac line that used to go into my cruise control(it hooks up to the intake manifold to a little tiny nipple) and ziptied the nylon line into the vac line...then stuck the vac line back onto the intake manifold.
Old Feb 24, 2005 | 09:09 AM
W O T's Avatar
Default Re: Boost Gauge In Hand. Something not right? *PICS* (SOHC_MShue)
lots of good ideas, I kinda wanna just stick the nylon line into a rubber line
Old Feb 24, 2005 | 09:33 AM
why do people wanna make mor work out of something simple. Use a bigger vac line and call it a day.
Old Feb 24, 2005 | 09:36 AM
portenio78's Avatar
Just do as ITR206 said, and get rid of that little *** line all together
Old Feb 24, 2005 | 11:39 AM
dustin's Avatar
When I had a mechanical boost gauge (for about a week till I decided it was junk and got a greddy), I just pushed silicone vacuum hose over the fitting on the back of the boost gauge and zip tied it. Worked fine.
Old Feb 24, 2005 | 11:42 AM
dunkd's Avatar
sick faze indiglo
Old Feb 24, 2005 | 10:05 PM
W O T's Avatar
Default Re: (dunkd)
hmm, I dunno which way to do it
Old Feb 24, 2005 | 10:09 PM
BlueShadow's Avatar
Default Re: (W O T)
do what?
Old Feb 25, 2005 | 04:59 AM
DaX's Avatar
DaX
Loved
Community Favorite
I'll try to post up a picture of the fitting on the back of my gauge tomorrow. I'm running 1/4" ID rubber fuel line from the gauge to the vacuum manifold.
Old Feb 25, 2005 | 09:42 AM
Kwuaymaikrup's Avatar
Default Re: (DaX)
Why not just keep the teflon line? You are making this WAY to difficult.
-Ryan
Old Feb 25, 2005 | 09:56 AM
JDM.Accord's Avatar
Default Re: (W O T)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by W O T &raquo;</TD></TR><TR><TD CLASS="quote">hmm, I dunno which way to do it</TD></TR></TABLE>
Damn d00d, it's not like you're about to spend your life savings here. Simple decisions oWnZ j00
Old Feb 25, 2005 | 10:36 AM
W O T's Avatar
Default Re: (JDM.Accord)
Its cool, there was 2 fitting on the gauge on the back of the unit, I only took off the one at first and the inner diameter fo the line to fit over it would have to be lime 1cm, but I just noticed another part was threaded and now the hole is perfect and will work with standard vacuum line
