Companies that make a 15.8+ rim.
i plan on running some wide fenders on the front of my eg and am having a hard time finding companies that make a rim in a 15x8 or 15x8.5. Can anybody help me? Thanks.
Modified by Pootie at 11:14 AM 2/24/2005
If you wanted one piece rims, they are very scarce and depend on the bolt pattern...
1) Volk had a 15x8 TE-37 for the 5x114.3, but I heard this was discontinued.
2) Kosei had a 15x8 K1 that you could only get through http://www.tirerack.com. Tire Rack was able to get blanks and would drill them to your specified pattern.
3) Revolutions in 15x8 are caried by http://www.ttrsracing.com/, but are cast and heavy.
If you wanted two or more piece rims:
4) There is a RacingHart CP-F TuneR in 15x8 4x100: http://www.hartwheels.co.jp/ca...c.htm
5) Work makes a few, the Meister S1-2P comes to mind.
Then there is always custom like http://www.kodiakracingwheels.com, Keizer, HRE, etc.
Just remembered a couple others, Gialla Volcano has 15x8 and 15x8.5 (4x100 only) and "NKB" (or something like that). Both are brands carried by one of the vendors here (Memory Fab)
From: hittin corners so hard you can taste my rims..
4X100 isn't the large of a stud circumfrance, and that susually means not much tourqe to require large tire size... your going to have a hard time finding a 8" wide 15" wheel.
im looking for 17" 4X100's for my integra ... only 2 out of 10 wheels offer it in 4 lug.
Guest
Posts: n/a
ANother option would to go with the JDM ITR 4 lug conversion since it uses a 4x114.3 bolt pattern. You'd find rims with the offsets your looking easier since the majority of RWD import sport compacts use that bolt pattern like the 1/2g rx7's, ae86, s13/s14, and some more but can't think of them right now. Look up places like Memoryfab or takumiproject.com or anyother jdm parts importer. Ebay can be your friend too.
