DX header
Old Feb 23, 2005 | 07:17 PM
UnitZero's Avatar
Default DX header
ok, to make a header fit on my 00 dx, I would need:
1) an exhaust made for an EX/SI
2) a stock or aftermarket cat for an EX/SI
one of the things I was thinking about was extending the o2 sensor. can I just extend the wires of my stock o2 sensor or do I have to get an ex sonsor? i cant remember but does the DX have 2 o2 sensors (before and after the cat) and the EX have only 1??
Old Feb 23, 2005 | 07:51 PM
UnitZero's Avatar
Default Re: DX header (UnitZero)
I found something like these,
http://images.channeladvisor.c...3.jpg
http://imagehost.vendio.com/pr...o.jpg
so would a cat and header with those plugs work together?
Old Feb 23, 2005 | 08:33 PM
eK9aT10pSi's Avatar
96+ will have 2 o2 sensors. i cant remember if you put a y8 header in a y7, the stock cat is too short or too long. but if you get a y8 header, get a y8 high flow cat and ur good. the one you should worry about is the one that goes into the header closest to the head. the one in the cat just tells you when your cat is bad. hook up an o2 sim to the one in the cat and your good
Old Feb 23, 2005 | 11:20 PM
UnitZero's Avatar
so I'll be fine as long as the header and cat have holes for the o2 sensors already right?
Old Feb 23, 2005 | 11:32 PM
JDMisGOOD's Avatar
Default Re: (UnitZero)
u can extend the wires
Old Feb 23, 2005 | 11:37 PM
UnitZero's Avatar
oh yeah, about extending the wires, I can use any kind of wires to splice into the 02 sensor right?
Old Feb 23, 2005 | 11:38 PM
JDMisGOOD's Avatar
as long as its the same wire
Old Feb 24, 2005 | 08:00 AM
Ghetto Civic HX's Avatar
I love to drive
Default Re: (JDMisGOOD)
I can't really tell form the pic, but that doesn't look like a real cat. It looks like a resonator with an o2 bung. You might get a CEL if you use that. It shouldn't hurt your performance, but you won't know if something else goes wrong because the light is already on.
On a side note...I have a Carsound cat for sale, if you're interested.
Old Feb 24, 2005 | 08:11 AM
civic-4-ges's Avatar
Default Re: (Ghetto Civic HX)
Make sure you get the header from a 96-98 EX....you will only have to extend the second set of 02 sensor wires
Old Feb 24, 2005 | 08:19 AM
wushubrian's Avatar
They make headers for our civic dx.
Old Feb 24, 2005 | 08:49 AM
young grasshoppa's Avatar
The DC Sports header for the EX comes with an O2 extension wire set that plugs right in. If you do have to splice, just makes sure you do a good job a route the wires away from the exhaust so it does not melt the wires.
Old Feb 24, 2005 | 11:14 AM
ntrider's Avatar
Last summer I placed a 4-2-1 header with similar looking cat in your pic. The only trouble I had was I stripped one of the O2 when removing it. Had it wrapped in aluminum foil for a while so I didn't throw a CEL. I went through two universals O2 before just buying a denso OEM from http://www.oxygensensors.com for like 100.00. With the universals I kept throwing CEL code 65 . I did make sure that both were wired correctly and check their resistants which was good. I had to go to the OEM because of I/M. The OEM went into my cat and the wires wouldn't reach so I grabbed a scalpel from work and carefully removed the wires from the conduit housing and re-wraped in new conduit and electrical tape.
Sorry for the novel but hope this helps
Old Feb 24, 2005 | 03:43 PM
UnitZero's Avatar
Default Re: DX header (ntrider)
actually it does help, thanks all
Old Feb 24, 2005 | 07:06 PM
eK9aT10pSi's Avatar
Default Re: DX header (wushubrian)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wushubrian &raquo;</TD></TR><TR><TD CLASS="quote">They make headers for our civic dx. </TD></TR></TABLE>
the ex ones have a bigger runner
RedRocketDX
Sep 12, 2009 07:19 PM
jdm integ
Feb 23, 2006 06:00 PM
CivicDx98
Feb 2, 2006 04:42 PM
anto13
Jul 12, 2005 01:12 PM
jdmgeorge
Feb 21, 2004 05:00 AM
