98LE Headlight Replacement
Old Feb 23, 2005 | 07:04 PM
antig24's Avatar
Default 98LE Headlight Replacement
Hello, on the passenger side of my accord, I have lost the low beam headlight. I went to Autozone and they said it takes a 9006 replacement, however we tried 3 different bulbs and none of them would fit in the socket. The diameter was too large when we checked it with a caliper by .100. I'm confused, is this headlight bulb a dual element and the other bulb is the parking light or is the parking light and lowbeam built into the same bulb? Can someone please shed some light on my questions. Thanks.
Old Feb 23, 2005 | 10:16 PM
iand415's Avatar
Default Re: 98LE Headlight Replacement (antig24)
the low beam is a whole separate bulb and it should fit, im not sure why its not
Old Feb 24, 2005 | 05:41 AM
hometheaterman's Avatar
Default Re: 98LE Headlight Replacement (iand415)
Should be 9006 are you sure your replacing the correct bulb? The other is 9005 well should be.
Old Feb 24, 2005 | 06:50 PM
antig24's Avatar
Thanks for your help. Much Appreciated. We got it fixed.
sipaboy
Honda Fit
Mar 5, 2019 09:03 PM
forestcd6
Apr 21, 2013 05:47 PM
G0NZ0
Honda Fit
Aug 6, 2012 08:03 AM
nObOdy65
Jul 29, 2006 04:45 PM
Don Jefe
Aug 17, 2004 04:34 PM
