205/50/15 or 195/50/15
Hey guys,
I'm gonna need some new tires pretty soon for some slips I just bought. They are 15x6.5 +40mm offset. I'm lowered on H&R sports. I have an EH2. I really don't want to rub at all, but I'd love to have some wider tires like 205's. Will I rub?
I'm assuming 92 civic? You should be safe with either. I have 205/40/16x7's on my 94 dropped 1.8" w/B18B1, no rubbing, although thats ~570mm tall, your tires are ~586 & ~576mm tall respectively. I know that in a 95 ex w/B18B1, 2" drop, 215/40/17's you'll occationally rip out the liners in the front...lol (wasn't my car)
i have 205s on both my cars with the same size wheels as yours.no rubbing problems,unless you ride around lowered 4" like a retard.
Chris
Chris
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VtecAddict96 »</TD></TR><TR><TD CLASS="quote">I'm on 205/50/15 and i rub when i take corners hard. I'm on H&R sports.</TD></TR></TABLE>
what size wheel and offset?swaybars?i have 500/400lb springs on my car i have very little body roll,but it still doesn't rub even when the car's twisted up when pulling into a driveway for example.
Chris
Chris
205's rubbed on the rear my 95 vx hatch with 15x6.5 +40 offset wheels when I hit bumps or turned really sharp. I had h&r sports and KYB agx's. I would go with the 195's. You will not have any problems with them rubbing and you don't have to waste more money buying new tires that rub.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dwnthehatch »</TD></TR><TR><TD CLASS="quote">205's rubbed on the rear my 95 vx hatch with 15x6.5 +40 offset wheels when I hit bumps or turned really sharp. I had h&r sports and KYB agx's. I would go with the 195's. You will not have any problems with them rubbing and you don't have to waste more money buying new tires that rub.</TD></TR></TABLE>
Do you rub even more when you have passengers in the car?
Also, what setting are your agx's on?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TeamNextGenChris »</TD></TR><TR><TD CLASS="quote">
Chris</TD></TR></TABLE>
No swaybars. Rays 15x7 i believe their something around +43 offset. I dont rub pulling into driveways, i just rub when theres like 4 people in my car or when i'm autocrossing.
No swaybars. Rays 15x7 i believe their something around +43 offset. I dont rub pulling into driveways, i just rub when theres like 4 people in my car or when i'm autocrossing.</TD></TR></TABLE>
Isn't that because there's too much positive offset?
15x6.5 wheels = 195/50/15
15x7 wheels = 205/50/15
You will have better handling charactaristics with the 195's on a 6.5 inch wheel. The sidewall won't feel as sloppy as 205's. If you run a 7" wide wheel, 205's are perfect. I have never had rubbing problems with my 205's on 15x7 wheels with a 35mm offset
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hatchtwIIn »</TD></TR><TR><TD CLASS="quote">with the 205 u will def. rubb, but wider is better okayer.</TD></TR></TABLE>read above.plenty of people with with 205s not rubbing.and wider is not necessarily better-again,read above.
Chris
Chris
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MiKeAhOwSkI »</TD></TR><TR><TD CLASS="quote">will a 195/50/15 fit on a 15x7 wheel though?</TD></TR></TABLE>
Yes it will.
Yes it will.
Try Putting 205's on the front, and 195's on the rear, will turn in more and seem to rotate more, creating more of a balance...
https://honda-tech.com/zerothread?id=847165
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by litterbox »</TD></TR><TR><TD CLASS="quote">
Yes it did. AGX's set at 2f/4r
15x6.5 wheels with +38 offset and i have 205/50's and they only rub when i turn really hard.
i have gc coils lowered to whatever is right above the tire with kyb agx's.
unless they're azenis, i think you should be fine. 205 azenis are more like 215 tires.
HiPhOpHeADs
Sep 14, 2006 10:08 PM
