Mini Me HELP!
Im having trouble with my mini me. Its a 95 eg with a d15b7(dx) block and a d16z6 head (ex/si)
- 1st the car wont start, it cranks but doesnt start only sometimes
- when i finaly get it to start, the timing belt makes this high pitched whyning noise because it rubbing on the side i guess that makes the noise
... i already checked the timing and readjusted the the tension on it as bauleycivic had told me. oh yeah i didnt buy the distributor with the head so i know the ignition timing is off.
some pics....
some pics....
1st: are you throwing any CEL's?
2nd: the whinning noise is just the belt being tight. If it kinda sounds like a super charger thats what it is. My mini-me swap does the same thing because the timing belt was extremely tight
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by delslo93 »</TD></TR><TR><TD CLASS="quote">1st: are you throwing any CEL's?
2nd: the whinning noise is just the belt being tight. If it kinda sounds like a super charger thats what it is. My mini-me swap does the same thing because the timing belt was extremely tight</TD></TR></TABLE>
the CEL cant even come on cus the engine is not even on that long and the whinning noise is REALLY LOUD!
Ill try to get some short vids tomarow, its really loud it sounds like the timing belt is being raped or something, similar to when you turn a car that has power steering all the way to one side and it makes that awful loud noise
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civichatch6989 »</TD></TR><TR><TD CLASS="quote">do you have the correct belt? (d16z6) also, if it doesnt stay running, there's probably a timing issue, is it off by a tooth? </TD></TR></TABLE>
yeah like what he said..might be because of you having incorrect belt thats making that whining noise..
the timing belt i have is the d16z6 (it says p28 on the belt). I think the cam gear is off by half a tooth or a tooth. Bauley told me that it should be half a tooth off either advanced or retarded.
if i am off by only one tooth will it really make my car not start?
ill try to get some vids tomarow morning its late now
im using a d16z6 dizzy that i bought off an HT member, is there anyway to tell for sure that it is infact a z6 one?
taht i cant say, i dun remember. you mightve turned the rotor 180 by accident. ive seen a few ppl that has done that. when you did your timimg belt, you set the crank and cam at TDC, correct ? id take out the dizzy rotate that piece by 180 and try starting it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eK9aT10pSi »</TD></TR><TR><TD CLASS="quote">taht i cant say, i dun remember. you mightve turned the rotor 180 by accident. ive seen a few ppl that has done that. when you did your timimg belt, you set the crank and cam at TDC, correct ? id take out the dizzy rotate that piece by 180 and try starting it.</TD></TR></TABLE>
yeah timing belt seems to be good, crank at TDC and cam gear at TDC . ill rotate the piece on the dizzy 180 degrees like you suggested. is there anyway to tell on the dizzy piece which way its supposed to be facing ?
yes if you have your timing belt off by even a tooth, it either wont run or if it does run it runs terrible.. did you make sure that the crank was exactly at TDC and that the head cam gear matched up with both the TDC marks on the plastic cam gear cover... also when you put the belt on sometimes the crank will move and you will no longer be at TDC..
Also it doesnt seem right to me for it to be whining, because i finished up a mini me swap on my brothers crx last week and i tightened up the tensioner as hard as i could and it doesnt whine...
And it wont really matter how the distributor is on there just put it somewhere in the middle.. couldnt it be possible that the distributor is 180 degress off? thats all i could think of
hey i got the car to start now, the timing on the cam pulley was off by a tooth and a half and on top of that it was loose.
now its running really rich and when i gas it in neutral, it seems to want to shut off and the rpms rise kinda lslow... could it be my ignition timing?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thrty8street »</TD></TR><TR><TD CLASS="quote">hey i got the car to start now, the timing on the cam pulley was off by a tooth and a half and on top of that it was loose.
now its running really rich and when i gas it in neutral, it seems to want to shut off and the rpms rise kinda lslow... could it be my ignition timing?</TD></TR></TABLE>
beat me to it..i was gonna say the belt looks loose as heck..and for the rest, looks like u pretty much know wat to look at
any time you make changes to your cam timing,
you must redo/adjust your ignition timing accordingly.
dont remember what exactly you have to to to the ignition timing,
but i'm sure you can find out.
also... check ur tps,
always check that durrned tps!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civichatch6989 »</TD></TR><TR><TD CLASS="quote">I would also recommend checking ur tps. </TD></TR></TABLE>
how do i check my tps? what could be wrong with it? what am i looking for when i check it? and what does the tps do?
Whining = triple check your belts.
then triple check your cam timing.
when my cam timing was off, it had a hard time stopping. It would turn over once or twice and get stuck. But sometimes it would start.
Good luck.
Good luck.
hey i got everything fixed today and my car is running pretty smooth
- the whinning noise was the alternator belt which was loose, it got tightened and it fixed the problem
- my friend did the ignition timing and now its idling good and there is no power loss.
thanks for the help everyone
...now im not sure if vtec is activating, maybe cus i still need those damn ecu pins
...oh and my temp gauge never goes up, it just stays all the way down all the time. anyone know what is causing this?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thrty8street »</TD></TR><TR><TD CLASS="quote">...oh and my temp gauge never goes up, it just stays all the way down all the time. anyone know what is causing this?</TD></TR></TABLE>
for the temp guage, the sender is under the dizzy. if it isnt plugged in, no signal to the cluster
for the temp guage, the sender is under the dizzy. if it isnt plugged in, no signal to the cluster</TD></TR></TABLE>
its plugged in i dunno why theres no signal maybe i should check it with a test light if it has power
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tad »</TD></TR><TR><TD CLASS="quote">u getting any cels ?
theres a couple that'll thrwo, like 21/22 when vtec aint workin</TD></TR></TABLE>
nope im not getting any CEL's at all im just saying it aint working cus i cant really hear it
you should never use a test light to check sensors, do you have a multimeter? check the resistance and the voltage. i,m not sure of the resistance but the voltage shold read 0-1 v and rise as the car heat up and then read 5v when warmed up. also have you driven the car sometimes my motor will never fully heat up untill i drive it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thrty8street »</TD></TR><TR><TD CLASS="quote">its plugged in i dunno why theres no signal maybe i should check it with a test light if it has power
nope im not getting any CEL's at all im just saying it aint working cus i cant really hear it</TD></TR></TABLE>
have you ever heard a sohc vtec engine before?
they dont sound like bseries, vtec is alot more subtle.
the changeover is harder to notice, but basically..
if your keeps on making power up on high ,then its working,
if it dies off like crap then its not.
