golden eagle intake manifold and fitting wiring harness
anyone have any pics or suggestions on how to best rig up the wiring harness so it fits? the manifold hangs down low enough so its such a tight fit running the wire loom past the throttle body.
no i think the wires are plenty long enough except only one --then IAT sensor plug.
the others should be ok but there is such a tight fit trying to route the loom from under the manifold past the tranny cables and rear mount on the passenger side.
The harness still hangs fine. You simply need to add length to the IACV sensor since it will not mount on the back of the manifold. You will also need to bend one of the master cylinder hard lines for fitment... you'll see which one when you go to install it.
yea, i meant iacv not iat sensor plug.
so you let the harness just hang there, you did not secure it with anything now that there is no brace there to clip the harness to?
thanks!
thanks!
1EK1EG
Northern California (Sales)
Jun 8, 2011 10:08 AM
