91 Accord leeking coolent and Check oil lights on
hey guys i have a 91 accord.. leeking coolent... i drove it kinda with almost an enpty radiator cause it leeked so the engine was HOT had to drive it to work and back 25 miles away i say engine temp was on the H.....car was running twice teh heat as normal......car is still leeking but added more coolent while ...still leeking but engine is not hot no more i;m gonan send it to the shop saturday
my brother said that cause the engine was so hot...i maybe melted soem gaskets or blew a cilinder head....don't knoe much i'm only 17 and too busy with school...should i tell my mechanic to check the internals and see what i have to replace....BTW the car is leekign coolent from under the engine not the radiator....close to the driver-front tire......thanx NE help will be fine
sounds like a bad water pump. thats what i have right now but i cant afford to fix. the leak isnt bad so i just keep adding coolent. you should get it that checked. also, is there a ringing sound that is noticeable above 2500 rpms? the hotter the eingine the quicker the oil burns off, so when you were driving it really hot for 25miles it probibly burned quite q bit of oil so check that too. make sure if you get it replaced or do it your self to put on a new timing belt too
yeha i'm gonan send it yo my dad's mechanic... chek the internals and everything i was thikin bout replacing everything it needs or i can just buy a new F22 engine for like around $500 bucks or something? with a manual tranny cause this one is stick so yeah but if i had the money i would just get an H22 but no $$$ thanx man i'm gonna get get it all fixed on Saturday it started heating up today a lil so when it cools down i'm gonan add water... is that good? it has 161,xxx miles and don't wanna keeo buying coolent and the sound for the 2500 RPM doesn't do it on mine but than i found some F22 for around $500 bucks on http://www.nippon-motorsports.com something like that thanx
FordWithAccord
Aug 3, 2011 11:55 PM
FarFetched
Jun 4, 2006 06:31 PM
