215/45?
Old Feb 23, 2005 | 03:58 PM
jdm_DC2R's Avatar
Default 215/45?
is there a 215/45R15 tire out there? i looked around for a bit, and got nothing. i currently have 205/50 now, on a 15 by 6.5" rim, but i want to go wider, yet keep the wall thin.
Old Feb 24, 2005 | 12:55 AM
XrcR6's Avatar
Default Re: 215/45? (AccordvtecR)
I highly doubt it, checking http://www.DiscountTireDirect.com and http://www.tirerack.com you can input that size and see it doesn't come up with any hits. Since they carry most/all the major brands, I doubt you're going to find anyone else making one in that size.
Are you going up in width for grip or appearance? Depending on what brand/model you have now, you could probably get a better tire in the same 205 size if performance is the goal. For instance Falken Azenis Sport (old/215 or new/615 models) or a Kumho Ecsta MX have a lot grip for a street tire while still being relatively easy on cost. Besides, @215 your existing rim width (6.5") isn't ideal and the tire will get pinched on it, causing vague turn-in feel. The contact patch probably won't be as wide as it should be either, so it would be a waste.
Old Feb 28, 2005 | 03:54 PM
jdm_DC2R's Avatar
im looking for better handling wise, not so much looks wise. i see wat u mean when u say to look at a better tire in the same size, my last set of 205/50R15 was Kumho 711, which was pretty good in the dry, but shitty in the wet.
i havent found any yet in the 215/45 size, so i guess ill just look for a better tire in 205/50.
Old Mar 1, 2005 | 06:19 PM
Jaker's Avatar
Default Re: (AccordvtecR)
Toyo T1-S is available in that size.
http://www.toyo.com/tires/tire_specsheet.cfm?id=2
Rooftop voter
May 21, 2009 05:10 AM
Civicse
Aug 29, 2006 05:57 PM
krayjeegsr
Jan 4, 2006 03:51 PM
johnxboi
Apr 4, 2005 02:50 PM
bb6h22a
Oct 30, 2003 06:27 AM
