HELP a guy who cant paint
Hey, ive never posted in this forum before and dont really to much cosmetic work but im in the middle of building a turbo Ls motor and want to paint the bloack and trans red, what paint should i use, primer, sanding material etc, please be detailed and only respond if you have good experience or you have a good red color suggestion thanks, also check my sig, pm me if you got what i need
Clean the block and trans with orange based degreaser, take 800 grit sandpaper and wetsand the block and trans. Use a sandable primer wait 30-45 minutes, then use hi temp red painit, there are tons taht are high heat, spray 3 coats total and wait 5 minutes between each coat.
