99' automatic tranny rattle HELP!!!!!!
Might not be the tranny, Accords seem to have some issues with the heat shield's on the exhaust coming loose. Have a TRUSTED friend sit in the car with the brakes on and have him put the car in drive, then take a piece of wood or something like that to push on the heat shield, it runs along most of the exhaust starting after the Catalytic converter. HOpefully this is the problem. You can either remove the heat shield or re weld it back together. I was an idiot and I put a hose clamp to hold it tight, this caused a rust problem and eventually a leak. Good luck!
Justice Sky
Mar 10, 2017 03:31 PM
underdog51
12
Oct 29, 2013 05:56 AM
