PLASMA CUTTER what are your thought about this unit
Here is the unit I'm talking about
http://www.harborfreight.com/c...91814
It's cheap, look like it will do the job, Mainly cutting 1/8, rarely up to 1/4 but does.
tell me what you think.
-Kranked
I seriously thought about it. Then I went and looked at it and decided I would rather spend $1000 once than $500 once and $1000 the second time..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Formula Racing »</TD></TR><TR><TD CLASS="quote">I seriously thought about it. Then I went and looked at it and decided I would rather spend $1000 once than $500 once and $1000 the second time..</TD></TR></TABLE>
^^^^^^^^^ worth quoting!!!
Personally, I havn't used that machine, but think about it...36amps max power!!!???? IF you can get it to cut 1/4" steel, it will chew it all to **** worse than a cut off wheel, and leave **** hanging off the back side about 1/2" long.
If you have ever used an underpowered plasma cutter, you know that it really sucks ***. It sucks *** even for demolition work, much less something you want to weld afterwards or make look nice.
Well sound's more crap than tool !
thank's
for the comment
keep em comming
Kranked
thank's
for the comment
keep em comming
Kranked
Yep well said !!
but I looked at it and it has the same power than a few other machine that worth 1000$
http://order.harborfreight.com...s.jsp
Then I realised there was no transfo in there, it's an inverter and it dosn't have the air compressor built in, but I don't want it with an air source I already have a good compressor.
Kranked
Yep well said !!
Kranked
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kranked91dx »</TD></TR><TR><TD CLASS="quote">
Yep well said !!
Kranked
Ok you REALLY need to stop thinking anything from harbor freight is anywhere near as good as a product from elsewhere. So it has an external compressor connection.. There is a reason its cheaper, and its not because they have the technology cheaper or they mark it up less!~ Im in the resale business and I coudl get a Truck load of harbor freight stuff.. I know the costs and there simply cannot be quality for the price!
Yep well said !!
Kranked
You'd be better off buying a used plasma cutter. We have a Hobart at the shop and it works great. Now we just need to get it on a circuit that won't trip every minute on the highest setting.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by backpurge »</TD></TR><TR><TD CLASS="quote">You'd be better off buying a used plasma cutter. We have a Hobart at the shop and it works great. Now we just need to get it on a circuit that won't trip every minute on the highest setting.
thank's for the imput guy's, I was actually looking toward a used plasma cutter but, I came across this unit in the mean time, making me think about it a bit,
Thank's !
kranked
</TD></TR></TABLE>thank's for the imput guy's, I was actually looking toward a used plasma cutter but, I came across this unit in the mean time, making me think about it a bit,
Thank's !
kranked
dont buy it. I bought a higher end model Hobart and it did a shitty job. I can image what this one would do.
Go with a Hypertherm or Miller
cant go wrong there.
fuck honda-tech
Sep 4, 2004 12:36 PM
