need cam caps torque specs for H22A asap. please
Old Jan 19, 2002 | 05:45 PM
mingchi96
Guest
Posts: n/a
Default need cam caps torque specs for H22A asap. please
instalilng new cams for friend but do not have the manual.. Anybody know the torque specs of the cam caps off the top of yr head, please share with me. Thanks
Old Jan 19, 2002 | 05:54 PM
migo's Avatar
New User
Default Re: need cam caps torque specs for H22A asap. please (mingchi96)
For the 12mm bolts-it's 12 ft-pd and the 10mm bolt it's 9 ft-pd. Always start in the middle and work your way out amd double check. Good Luck.
Old Jan 19, 2002 | 08:01 PM
mingchi96
Guest
Posts: n/a
Default Re: need cam caps torque specs for H22A asap. please (D.specs)
that cant be right man.. I know that the b-series head cam caps are suppose to be torqued @ 20 ft/pds.. can the h22a differ that much in torque specs??
Old Jan 20, 2002 | 06:24 AM
migo's Avatar
New User
I just finish putting my whole motor together, and I've this procedure many times....Plus this is not a B-serious motor any ways.....
YOU DON'T HAVE TO TAKE MY ADVICE....
[Modified by D.specs, 7:26 AM 1/20/2002]
Old Jan 20, 2002 | 06:31 AM
G's Avatar
G
Please don't torque the cap bolts to 20ft.lbs. It wouldn't be fun removing the other half of the bolt from the head..........
SpoonCivicSir20
Oct 16, 2008 02:08 PM
MLBZ521
Jul 27, 2005 06:25 PM
Tripz
Aug 4, 2003 03:25 AM
vtec93accord
Apr 14, 2003 12:46 PM
