J35 with CL-S heads in a 6th gen Accord.
Old Feb 23, 2005 | 01:09 PM
Default J35 with CL-S heads in a 6th gen Accord.
What all would be needed to do this? Just a J35 longblock and CL-S heads? Which J35 would be best? Would headers for a 6th gen Accord still work? Would the 6th gen Accord intake manifold still work? What are the available transmissions, both auto and manual? Is there a better website to ask all of this?
Old Feb 24, 2005 | 11:14 AM
Default Re: J35 with CL-S heads in a 6th gen Accord. ("Hites")
Old Feb 24, 2005 | 11:45 AM
Legendaryyaj's Avatar
Go to V6performance.net. Theres one guy on there that has done it. Its also supercharged with a custom intake mani with intercooler. Hes running the Odyssey 3.5 block with CLS heads. I believe you need different pistons to clear the head. I cant believe I never told you about the site. You can use the Accord headers and everything. The CLS tranny will swap as well as just about everything else.
Search for TAG or Jimmyrecluse. Tag has the 3.5 monster and jimmyrecluse had the 3.2cls swap with 6spd tranny. Jimmyrecluse has since sold his car though. The swap will run you near 10g's if you want the 3.5 while the regular 3.2 with cls 6sp is like 7g's.
If you plan on running the CLS heads the Accord intake mani wont work correctly. You need to use the type S heads because of all the sensors and stuff. You can also use any of the J35 blocks I believe.
Old Feb 24, 2005 | 03:12 PM
ODUB's Avatar
yeah
Old Feb 25, 2005 | 11:58 AM
Default Re: J35 with CL-S heads in a 6th gen Accord. (Legendaryyaj)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Legendaryyaj &raquo;</TD></TR><TR><TD CLASS="quote">Go to V6performance.net. Theres one guy on there that has done it. Its also supercharged with a custom intake mani with intercooler. Hes running the Odyssey 3.5 block with CLS heads. I believe you need different pistons to clear the head. I cant believe I never told you about the site. You can use the Accord headers and everything. The CLS tranny will swap as well as just about everything else.
If you plan on running the CLS heads the Accord intake mani wont work correctly. You need to use the type S heads because of all the sensors and stuff. You can also use any of the J35 blocks I believe.</TD></TR></TABLE>
so the pistons on the j35 rise slightly above the edge of the opening of the block? that sucks. thx for the link.
Evildragonr
May 13, 2007 09:07 PM
V6 Cylinder
Feb 25, 2006 04:05 PM
hondasport0023
Jan 12, 2005 05:46 AM
James
Dec 3, 2003 07:37 PM
