Right Front Brake Making Scrapping Sound
Old Jan 19, 2002 | 05:42 PM
onyx00's Avatar
Default Right Front Brake Making Scrapping Sound
Whenever I step on the brakes I hear a scrapping sound on the right front wheel. I had previously installed brake lines and brake pads last week and had no problems and no sounds. No after bleeding the brakes this weekend, this scrapping sound started all of a sudden.
Should I be worried? It sounds like when the wheel is moving, and the brake pad goes to grab the rotor, there is scrapping on and off as the rotor spins.
Should I be worried about this? Ideas? Suggestions?
Thanks!
Old Jan 19, 2002 | 06:37 PM
Teepo's Avatar
Default Re: Right Front Brake Making Scrapping Sound (onyx00)
take the wheel off inspect the work you had done......maybe the backing plate is rubbing against the rotor or the shims were not properly installed. Also check your caliper bolts and axle nut, you wouldnt believe the ive seen !
crxaddikt
Sep 29, 2013 12:29 PM
CWBETB
Jul 31, 2007 05:56 PM
TrakDay
Oct 25, 2006 06:29 PM
casmello
Oct 16, 2005 11:14 AM
mikeds122
Sep 25, 2004 12:55 PM
