HELP?!?? ITS EVERYWHERE!
Old Feb 23, 2005 | 09:26 AM
JD95hatch's Avatar
Default HELP?!?? ITS EVERYWHERE!
Rust that is...
Ive had my car sitting in front of my house for about a month now since ive been away at school and i came home to look at it...and there is RUST everywhere....its only surface rust but its still annoying to have a pretty silver finish turn orange and brown...especially on my new turbo....
What should i do to clean it WD40 and a wire brush?
Is there anythign i can do to prevent it from happening in teh future..paint/coating?
Old Feb 23, 2005 | 09:33 AM
SOHC_MShue's Avatar
Default Re: HELP?!?? ITS EVERYWHERE! (JD95hatch)
yup thats what happens when you don't paint them.
Old Feb 23, 2005 | 09:35 AM
beepy's Avatar
Default Re: HELP?!?? ITS EVERYWHERE! (SOHC_MShue)
Put a Zinc cathode around the exhaust at some point. I don't know why more car owners don't follow the anti-rust practices that have been used in the boating industry for 100 years!
Old Feb 23, 2005 | 10:22 AM
JD95hatch's Avatar
Default Re: HELP?!?? ITS EVERYWHERE! (beepy)
whats zinc cathode?....
Old Feb 23, 2005 | 10:38 AM
sbiggi's Avatar
Thats what mild steel will do.
I bet if you get it hot, alot on the turbo will come off.
Other then that, paint your IC pipe or replace with stainless/aluminum
Old Feb 23, 2005 | 10:48 AM
D-booster's Avatar
what turbo are you running?...looks like a precission, reason I ask is my sc50 turbine section has a silver looking coat on it and was thinking it must coated from the factory, but not sure. I want to know if yours(turbine section) was silver before you installed it.
Old Feb 23, 2005 | 10:53 AM
DurboDug93's Avatar
Default Re: HELP?!?? ITS EVERYWHERE! (D-booster)
I think zinc cathode is that plate that sits on the Lower unit of a boat motor(the part that sits in the water). I thought the purpose of the zinc plate was to attract barnacles so they dont grow on the foot. I didnt think it was for rust
Old Feb 23, 2005 | 11:06 AM
Quad-Damag's Avatar
Default Re: HELP?!?? ITS EVERYWHERE! (DurboDug93)
sand off the rust and paint the stuff with high temp heat paint
1400 degree stuff is real nice
t0p_sh0tta's Avatar
They are for rust IIRC, but doesn't the salt in the water have something to do with their anti-rust properties?
Old Feb 23, 2005 | 12:10 PM
JD95hatch's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by D-booster &raquo;</TD></TR><TR><TD CLASS="quote">what turbo are you running?...looks like a precission, reason I ask is my sc50 turbine section has a silver looking coat on it and was thinking it must coated from the factory, but not sure. I want to know if yours(turbine section) was silver before you installed it. </TD></TR></TABLE>
ya...it was a brand new sc50...heres what it looked like b4...all perrdy
So all i should do is take some high temp paint to it?....is it safe on everyhting...i still want the turbo to have a natural finish....does anyone have any pics of their setups?
Old Feb 23, 2005 | 12:11 PM
NJIN BUILDR's Avatar
http://www.napaonline.com/cgi-...grpid=
Just get an acid brush and follow the directions.
Glenn
Old Feb 23, 2005 | 12:23 PM
s2kdre's Avatar
Default Re: HELP?!?? ITS EVERYWHERE! (NJIN BUILDR)
its cast iron its gonna do that as soon as moisture hit it. Just jet coat it, But its not worth the money unless its a show car.
Old Feb 23, 2005 | 12:39 PM
richeybrooks's Avatar
Default Re: HELP?!?? ITS EVERYWHERE! (jdmhonda)
they make an asid that takes car of surface rust great! a lot better than wd40
Old Feb 23, 2005 | 12:41 PM
bk11383's Avatar
you don't have to have a show car to get your turbo housing jet hot coated. granted yes it is a bit pricey but it will 1 protect your turbo from rust later on and 2 it will help your spool time get faster. minimal but it still serves a purpose than just makin it pretty.
Old Feb 23, 2005 | 12:43 PM
kKdARIAN's Avatar
Vice President/CEO
Default Re: HELP?!?? ITS EVERYWHERE! (richeybrooks)
wow.. that really does suck though'
Old Feb 23, 2005 | 01:03 PM
JD95hatch's Avatar
Default Re: HELP?!?? ITS EVERYWHERE! (kKdARIAN)
lol..ya it sucks..i opened my hood and was like WTF!?!
but ya i heard of that jet coating...i heard it reduces temps like no other..so im guessing it would only help if i had my manifold done or the turbo housing.
Old Feb 23, 2005 | 01:11 PM
JalopySiR's Avatar
I just used the high temp engine paint from Wal-mart (1500). Taped off the manifold and turbine housing, painted em' up, threw em in the oven on high for a while. Looked great. I just don't have the money for a "coating" but I don't like rust either.
Old Feb 23, 2005 | 01:14 PM
JD95hatch's Avatar
Default Re: HELP?!?? ITS EVERYWHERE! (JalopySiR)
got pics
Old Feb 23, 2005 | 02:34 PM
platinum00's Avatar
if you leave the rust on the turbo housing will it effect anything.
platinum.
Old Feb 23, 2005 | 03:22 PM
JD95hatch's Avatar
Default Re: HELP?!?? ITS EVERYWHERE! (platinum00)
i dont think it woudl affect anything...but the appearance...but i dunno..
Old Feb 23, 2005 | 03:28 PM
beepy's Avatar
Default Re: HELP?!?? ITS EVERYWHERE! (t0p_sh0tta)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by t0p_sh0tta &raquo;</TD></TR><TR><TD CLASS="quote">They are for rust IIRC, but doesn't the salt in the water have something to do with their anti-rust properties?
Simple explanation: Rust is an electrochemical reaction. That means that a very tiny current is developed as something rusts. Any water (except distilled) will cause rust. Why? Because water conducts electricity and allows the chemical reaction to occur. Salt water simply speeds up the process because salt water is a much better conductor than fresh water.
What a zinc cathode does is to prevent the iron from oxidizing, simply by drawing the reaction to itself. Zinc is a more electronegative element than iron and wants to form an oxide more than iron does, in other words.
The zinc is often called a "sacrificial electrode" for this reason. Basically you attach a zinc to the steel, and the zinc will corrode instead of the steel. You just replace it when it gets badly corroded. (several may be needed)
Old Feb 23, 2005 | 04:57 PM
forgotmypassword!(OTT)'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DurboDug93 &raquo;</TD></TR><TR><TD CLASS="quote">I think zinc cathode is that plate that sits on the Lower unit of a boat motor(the part that sits in the water). I thought the purpose of the zinc plate was to attract barnacles so they dont grow on the foot. I didnt think it was for rust</TD></TR></TABLE>
lol ROFL Classic, someones fooled you with that story for sure.
Old Feb 23, 2005 | 05:11 PM
*Boostwerks*'s Avatar
thats why stainless or Aluminized steel is great.
Takes a long *** time for those to rust/oxidize.
tyronne1126
Paint and Body
Jun 26, 2009 05:00 PM
skyman88
Welding / Fabrication
17
Dec 9, 2007 12:28 PM
DJ Stimpy
Jul 8, 2007 08:49 AM
UCLA.lion
Apr 2, 2007 10:36 PM
rex_racer728
May 24, 2006 02:02 AM
