what is the lowest offset you can runs on your EG?
I forgot more about hondas then you will ever know....
From: hop,skip, and a jump from the city,, new friggin york, USA
i run 8.5" wide wheels that are +19mm.....
anyone else know about this? im planning on buying some 15 x6.5 with a 35 offset will i rub on a eg?
just installed a 15x6.5 +25 offset with 190 50 15, need to roll the fender in the rear, fit very good, no rub with hard corner, I think you should be fine with +30
Modified by The Tea-father at 11:28 AM 2/28/2005
i have some 15x7 volks with a 35 offset and i'm tuckin the fronts.. rubs a little cuz i got some 205s on too.. should be koo.. my camber is set to 1.5 but i might go 2.25 when i get some stiffer springs..
[QUOTE=The Tea-father]just installed a 15x6.5 +25 offset with 190 50 15, need to roll the fender in the rear, fit very good, no rub with hard corner, I think you should be fine with +30
dem weds!?
dem weds!?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by The Tea-father »</TD></TR><TR><TD CLASS="quote">just installed a 15x6.5 +25 offset with 190 50 15, need to roll the fender in the rear, fit very good, no rub with hard corner, I think you should be fine with +30
Modified by The Tea-father at 11:28 AM 2/28/2005</TD></TR></TABLE>
Anyone have a pic of this set up 15x6+25 offset on there eg? thanks
eghatchback94
Sep 28, 2012 09:15 AM
