Fully Ported/Built Head Comparison (B18A/B ::&:: VTEC Heads)
Old Feb 23, 2005 | 07:41 AM
DragSource's Avatar
Default Fully Ported/Built Head Comparison (B18A/B ::&:: VTEC Heads)
I have seen the topic of "which head is better" and so on a million times. It's pretty much common knowledge that the VTEC heads flow better than the LS heads, and that they have a better valvetrain to start with. . . but I have never seen a comparison of both heads fully ported and built. Also - this is speaking in terms of Forced Induction only. . . as this is the FI forum.
Of the heads, assuming they were both FULLY PORTED, and COMPLETELY rebuilt.
Would one head stand out remarkably above the other? Would there be a slight advantage to one over another. . . or none at all?
Old Feb 23, 2005 | 07:52 AM
non-VTEC's Avatar
Default Re: Fully Ported/Built Head Comparison (DragSource)
the VTEC heads have largers intake valves and ports. you can only open up the non-VTEC intake ports so much without making it flow worse than stock.
the VTEC head will perform better even if they were both worked over pretty good..
i do belive some people have tried to get the non-VTEC head to flow as good or better than the VTEC head but its really hard and not many people can get it to flow.....maybe with new valve seats/larger valves???
Old Feb 23, 2005 | 08:35 AM
DragSource's Avatar
What about the LS head makes it so that if you open up the intake valve ports more than "so much" that it will flow worse?
Old Feb 23, 2005 | 08:48 AM
tokesGTR's Avatar
Default Re: (DragSource)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DragSource &raquo;</TD></TR><TR><TD CLASS="quote">What about the LS head makes it so that if you open up the intake valve ports more than "so much" that it will flow worse?
You start to sacrifice velocity, swirl, and low lift flow to get another 1 or 2 CFM's on the top end. Remember on a cam with say .445 lift, the valve is only at .445" for a fraction of the entire time it's open, so if you throw away all your low lift potential for a bit more top end you can actually end up hurting power production. The VTEC head is cast differently, and allows more flow and power potential in a full on application.
Old Feb 23, 2005 | 09:43 AM
DragSource's Avatar
I see what you're saying.
So at any given PSI, on a full on race application - the vtec head will make more power.
How significant of a difference is it on 2 worked over heads. . . both ported?
I know it's hard to make comparisons b/c you can't really make a scenario with equal cams, etc to make it a legit comparison.
Lets just throw out a number. If I had a fully ported and built LS head w/ oversized valves, etc and I swapped it for a fully ported vtec head w/ all the goodies.. . . how much horsepower would I gain.
I know that's a rediculous question and impossible to answer - but I'd love to know!
Old Feb 23, 2005 | 10:54 AM
thehatchninja's Avatar
100 hp....trust me y0! one of mah homi3z did it.
Old Feb 23, 2005 | 12:35 PM
DragSource's Avatar
riiiiiggggggttttttt. . . .
pleej
Mar 18, 2015 08:56 PM
blurry454
Jun 28, 2009 10:33 PM
90teg91hatch
Sep 11, 2008 08:36 AM
mstewar
Nov 15, 2005 07:57 AM
98lsskunk
Sep 24, 2005 07:36 PM
