antenna wire broke :(
Old Feb 23, 2005 | 07:13 AM
Slvr_CRX's Avatar
Default antenna wire broke :(
I was removing my radio and the end of the antenna wire comming from the antenna the head got stock in the other end that is connected to the radio. I was wondering what someone might do to fix this? I was think i can just cut both ends off and then get another wire and use that to connect it but not sure if all the antenna wire is a wire or if there more to it then that. Thanks for your help.
Old Feb 23, 2005 | 07:23 AM
AutoXer's Avatar
Default Re: antenna wire broke :( (Slvr_CRX)
So you're saying the connector from the antena is stuck in the radio wire socket?
Like this:
Ant wire -----[-|Plug|-]----- radio wire----[radio]
I'd throw some PB Blaster on it and get out pliers / vice grips before I went cutting anything.
Old Feb 23, 2005 | 07:27 AM
Slvr_CRX's Avatar
Default Re: antenna wire broke :( (EX_AutoXer)
when i pulled the wire out everything came out except the wire head ||-- and its to small to get out. even if i get out i can put that part back on the wire cuase its cracked. Dose that make sence?
spoolinvtec54
Nov 23, 2013 05:56 PM
Blammo300
Audio / Security / Video
Dec 10, 2005 12:21 PM
CrazyModGSR
May 14, 2004 10:21 PM
