92 civic cx hb signal lights
Old Feb 23, 2005 | 06:00 AM
jeebus6944's Avatar
Default 92 civic cx hb signal lights
So my left turn signal burnt out on me last week. I replaced it but now when my lights are turned on, the flasher stays on. I have a remote starter which i heard could cause problems but i tried resetting it with no results. If my lights are off, the flasher works. Anyone have some ideas
Old Feb 23, 2005 | 06:17 AM
BMAN93si's Avatar
Default Re: 92 civic cx hb signal lights (jeebus6944)
what you mean it stays on??? i had the same problem with the apc bulbs that come with my corner lights...are they apc bulbs???
Old Feb 24, 2005 | 08:04 AM
jeebus6944's Avatar
Default Re: 92 civic cx hb signal lights (BMAN93si)
to be honest i'm not 100% sure if they are APC bulbs. How can I find that out. But by the sounds there is a good possibility that they are and maybe I got the wrong bulb ?
Old Feb 24, 2005 | 08:07 AM
BMAN93si's Avatar
are they clear corners???? becus if they are then get yourself the hyper white bulbs......the bulb is blue but they are white.....10 bucks a pair here(canada).....if you dont have clear corners.....just get some oem 1157's...good luck
cstone
Nov 23, 2009 03:38 AM
16v
Lighting
Jan 18, 2008 12:32 PM
xmx250
Honda Civic (2006 - 2015)
Apr 9, 2007 08:38 AM
vinai
Nov 17, 2004 09:11 AM
