getting car tuned
Old Feb 22, 2005 | 10:51 PM
UNKNOWN_MEMBER's Avatar
Default getting car tuned
Anyone know if a bad o2 sensor will mess up the tuning? Or will it be koo to get it tuned with the bad o2 sensor then save up some money and get a new o2 sensor?
Old Feb 23, 2005 | 08:25 AM
civic-4-ges's Avatar
Default Re: getting car tuned (UNKNOWN_MEMBER)
Bad o2 sensor will not give accurate reading to the ECU
Your tuner should be using a wideband...which should work just fine
Your bad o2 however could cause your ecu to adjust a/f ratio incorrectly and throw off the tuners work
Change it if its bad, especially if you know
Old Feb 23, 2005 | 11:05 PM
That's the thing, it's throwing a code every now and then and i'm hoping its the o2 sensor cause I get bad mileage. And I can't find the harness to connect the paper clip to.
Modified by UNKNOWN_MEMBER at 4:56 AM 3/7/2005
skatesalot
Oct 17, 2005 03:29 PM
boost fed ls
Aug 31, 2004 07:45 PM
Shakes
Apr 28, 2004 08:45 PM
ironchef25
Feb 3, 2004 04:32 PM
