question about the 00-01 itr ignitions. can it be used on civic?
Old Feb 22, 2005 | 09:37 PM
fullraceacura's Avatar
Default question about the 00-01 itr ignitions. can it be used on civic?
i found an 00 itr ignition on ebay and was wondering if this could be used on my hatchback, what is different about how this ignition works instead of a regular ignition
i will need to swap my 98 p73 for a "green key" 00 ecu too right
Old Feb 22, 2005 | 10:09 PM
Chris F's Avatar
Default Re: question about the 00-01 itr ignitions. can it be used on civic? (itr#xxxxlives)
Hybrid forum not have any answers for you? I have no idea, but good luck.
Old Feb 22, 2005 | 10:12 PM
ZygSpeed's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by itr#xxxxlives &raquo;</TD></TR><TR><TD CLASS="quote">i found an 00 itr ignition on ebay ...</TD></TR></TABLE>
The key/switch assembly in the steering column?
You should only need a special key when used with an ECU that has the immobilizer "thingie".
Old Feb 22, 2005 | 10:27 PM
Default Re: question about the 00-01 itr ignitions. can it be used on civic? (Chris F)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chris F &raquo;</TD></TR><TR><TD CLASS="quote">Hybrid forum not have any answers for you? I have no idea, but good luck.</TD></TR></TABLE> would hybrid be able to help with with switching ignitions?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zygspeed &raquo;</TD></TR><TR><TD CLASS="quote">
You should only need a special key when used with an ECU that has the immobilizer "thingie".</TD></TR></TABLE>
im asking if i can use that special ignition and get an ecu with the immobilizer feature as an extra safety precatuion, will evertyhing wire up and work??
if somebody comes to steel my hatchback the last thing they are going to expect is a type r immobilizer
Old Feb 22, 2005 | 10:28 PM
97 civic dx is what the ignition is going into
dmefb18
Mar 31, 2007 07:12 PM
Schurke
Dec 27, 2006 11:11 AM
atmosphere
Aug 30, 2005 08:52 PM
hondahans
Dec 26, 2003 12:33 PM
locass316
May 12, 2003 11:32 AM
