shift stuck at park
Old Feb 22, 2005 | 06:51 PM
yellowdcn's Avatar
Default shift stuck at park
my auto accord is stuck on park and i cant shift it unless i stick the key in. i removed the shift **** and i cant even push the metal stick that supose to unlock the shifting. anyone know any idea of the problem?
Old Feb 22, 2005 | 07:17 PM
CB7VTEC's Avatar
Default Re: shift stuck at park (yellowdcn)
Most likely the brake switch. The shift lock solenoid will not let you move the select lever without a signal telling it that your foot is on the brake.
Old Feb 22, 2005 | 09:30 PM
yellowdcn's Avatar
Default Re: shift stuck at park (CB7VTEC)
wat do u mean by brake switch ? can u specify?
Old Feb 22, 2005 | 09:49 PM
CB7VTEC's Avatar
theres a switch that your brake pedal actually comes in contact with on the pedal assembly behind the lower dash
Old Feb 22, 2005 | 09:54 PM
2JZMadison's Avatar
Stomp the foot brake and rip back with all your might...That should solve your problem....but it might create others Use technique at your own risk!
Old Feb 22, 2005 | 09:55 PM
accordselux's Avatar
Me Gusta History
Default Re: shift stuck at park (2JZMadison)
Ugh. There's a key sized slit by your shifter. Stick a screwdriver in there and it resets the shifter. That should fix it
Old Feb 22, 2005 | 10:08 PM
raceACCORDingly's Avatar
^ reading owns you. he can only move his shifter when he stick his key in the slit
Old Feb 22, 2005 | 10:47 PM
yellowdcn's Avatar
Default Re: (raceACCORDingly)
once i get it out of park, everything is all good. The problem is that i cant shift it out of park w/o the key in the the key shift release
Old Feb 23, 2005 | 10:54 AM
flight50's Avatar
Default Re: (yellowdcn)
Did you just get the car or you had it for awhile and this just happened. How many people drive your car. I am thinking that someone activated your shift lock and you can't deactivate it. I know that without pressing the brake, you won't be moving your shifter.
Old Feb 23, 2005 | 11:31 AM
Me Gusta History
Default Re: (flight50)
I had a problem like this and they had to replace the cable or whatever connects the shifter to the transmission. That was 200 some bucks but under warranty
Old Feb 23, 2005 | 03:48 PM
yellowdcn's Avatar
Default Re: (accordselux)
it was at a shop for about 2 weeks getting painted and stuff and when i got it back, it wouldnt shift and my horn doestn work. I got it back on Monday. I fixed teh horn but dont know what is wrong w/ the shifting! Damn shop ! I also had to replace my battery cuz it kept dying on me when i got it back!
Old Feb 23, 2005 | 06:16 PM
Me Gusta History
Was it honda, a chain, or an independent shop?
Old Feb 23, 2005 | 08:20 PM
yellowdcn's Avatar
independent shop
Old Feb 23, 2005 | 09:14 PM
patastinky's Avatar
Could be your shift linkage. Check that out probably too loose. Or the connecters are not lined up! I replaced mine on my 90dx because it was too loose. Any time i put it into park and tried to get it out it was very hard to do so.
Old Feb 23, 2005 | 09:56 PM
yellowdcn's Avatar
Default Re: (patastinky)
ill try to fix it on teh weekend with all teh advice hopefully i dont mess it up even more
Old Feb 24, 2005 | 01:07 PM
Brycen's Avatar
my girlfriends accord did that her is a 92 auto and it would not shift out of park but if you look at night when you turn the car on look at the indicator on the cluster if the lights are out i found that it was a fuse.A backup fuse r whatever it is.
Old Feb 24, 2005 | 01:42 PM
newdad's Avatar
DUDE what is wrong with all of you? hey have somebody press on the brake and you look at the brake lights if the brake lights dont work which am more than posssitive they dont just have the brake light switch replaced is by the brake pedal, and is bad and it wont let your car come out of park trust me on this one
Old Feb 24, 2005 | 05:20 PM
yellowdcn's Avatar
Default Re: shift stuck at park (newdad)
wat u say newdad?
so to start my car i stick the key into teh shiftunlock and i put it in neutral then i start my car which works fine. Once i start my car, on my cluster, the neutral square lits up as well as the d4 square which goes away in like 5 sec. Is this natural like your accord ?
Old Feb 24, 2005 | 05:40 PM
NiBlazed's Avatar
Hes saying just check your brake light fuse. If that fuse is blown you wont be able to shift out of park without putting the key in the shiftlock hole.
This happened to me to, i was driving around for like a week with no brake lights and i aint even know it.
Old Feb 25, 2005 | 05:06 AM
or the brake switch like cb7vtec said. theres a switch that is on the brake pedal assembly when you step on the brake pedal it activates the switch and turns on your brake lights and also releases the lock up solenoids so that you can shift into drive.
Old Feb 25, 2005 | 03:45 PM
-pariah-'s Avatar
My 89 is having the same problem. It won't even start unless it is in Neutral
Old Feb 25, 2005 | 05:07 PM
yellowdcn's Avatar
Default Re: shift stuck at park (-pariah-)
omfg u guys are ******* smart my brakelights do not work!!!! thats probably the problem huh like u guys said.............. do i need replace the fuse or wat ?
Old Feb 25, 2005 | 05:08 PM
yellowdcn's Avatar
so its under teh break peddle? hopefully its the problem !
Old Feb 25, 2005 | 05:10 PM
yellowdcn's Avatar
anyone know what kind of fuse it is? or when i buy it it should say wat it is for ?
Old Feb 25, 2005 | 09:42 PM
yellowdcn's Avatar
night bump
