Crazy Custom RMF header and b16 Head with major mods
Old Feb 22, 2005 | 06:22 PM
Speedz's Avatar
Default Crazy Custom RMF header and b16 Head with major mods
NOTE: this ISNT my head or header.. just Re posting the head pics that were originally posted in JerryBuilt's thread.. and posting up the custom header to match the head... Pretty crazy fab skills there RMF!!!
any more info you wanna share on this?
Modified by Speedz at 7:03 AM 3/1/2005
Old Feb 22, 2005 | 06:32 PM
Casey's Avatar
Default Re: Crazy Custom RMF header and b16 Head with major mods (Speedz)
r u ******* kidding me?
that is pretty crazy
care to give some reasoning behind the design?
Old Feb 22, 2005 | 06:33 PM
Combustion Contraption's Avatar
What the ****??
Looking good RMF, but i just have one question....
Since the 'wall' (dont know the technical term here) that divides the exhaust port smoothes out and ends (obviously) before the head casting 'ends', what benefit does setting up those two chambers in the front of the primaries add? Dont get me wrong, the design looks great, but we both know looking great & making power are 2 different things! Thanks for any info in advance....
Old Feb 22, 2005 | 06:40 PM
lohatch's Avatar
do you have any pics of the header that was used to make more power on this head??? you said something about this header making about 10hp less than a different one?? a lot of work into that setup.
Old Feb 22, 2005 | 06:44 PM
Speedz's Avatar
quoted from RMF on the JB thread
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RMF &raquo;</TD></TR><TR><TD CLASS="quote">Well it started 5yrs ago .Chris Whitfield gave me a B-16 head that lost a valve.It ruined #1 and i told him I could fix it.Well I got a little carried away.The top pic.I welded the floor up and welded the divider all the way out.That was so I could flow each valve separate.Also straightened out the port.They don't point in anymore.
The next pic.I figured out the area of 1 valve less the dia. of the stem.Then I raised the port up until it went into the spring pocket.I made 8 tubes
the size that I wanted .I bored the holes and welded the tubes in.The adapter flange is so I could run ITBs.Because under that flange there is 8 separate ROUND holes.The flange is for the transition from 2 holes to 1.And that's a B-16 bolt pattern.
The next pic is showing how much I took off the head .Over .100".The reason for that was .To have a smaller combustion chamber and a bigger quench
area.Also to get the quench area closer to the piston.I didn't want a tall dome piston to block off the valves.
I also put .200 longer guides in because the stems are so small that the valves want to move around and the air passes around the guide better than a stem going up and down.(the guides are real small dia. though).
The head is not made of virgin 356 that's for sure.But I used 5356 with straight helium on DC straight.You just can't let it get to hot or it goes soft.Allum.
loses its heat treat after about 600deg.
OK #s At first with the adapter plate .The IN. flowed 296 with 28" @ .500.But without it 306" " But I think I fixed that.And on the EX. 226" ".The important
thing is how much power it made.OH and yes I made a set of headers with 8- 1 3/8
tubes and 2 baby merge collectors.I put the left side of the ports in one collector and the right side in another.Its the most wild set of headers you have ever seen.
One problem they lost 10hp over a drag style with a different flange.But man they sure look good hanging on the wall.</TD></TR></TABLE>
Old Feb 22, 2005 | 06:45 PM
Ekasey's Avatar
i like the styling of that header
dunno about the whole split port deal though
Old Feb 22, 2005 | 07:09 PM
RMF
Guest
Posts: n/a
Default Re: (LsVtec92Hatch)
It started off .I was just going to straighten out the exhaust ports.And raise the floor.But I couldn't flow each valve separate.So I brought the divider out to the end
of the port.
Then I thought all the 500cc single motorcycles have split primaries.And they make a bunch of power for their size.Then I asked everybody that I thought might have a clue.About running that configuration.
And nobody has seen or heard of anyone trying that.So I tried it.The worse thing that could happen would be that it wouldn't make power.And that's exactly what happened
I put a drag style header on and it made 10 more HP and 10 more ft.lbs.
of tq.But the head made a bunch more power than a (big name ported)GSR head.
With ITBs.It made almost 27 more hp.And boy is it responsive
If I confused anyone ,only the HEADER didn't work .But the HEAD did work ,GOOD
Modified by RMF at 8:49 PM 2/22/2005
Modified by RMF at 8:51 PM 2/22/2005
Old Feb 22, 2005 | 07:34 PM
2k.civic.si's Avatar
Default Re: (RMF)
so it was a success or no? im lost by your last post
Old Feb 22, 2005 | 07:51 PM
91' LS-VTEC's Avatar
Default Re: (RMF)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RMF &raquo;</TD></TR><TR><TD CLASS="quote"> And nobody has seen or heard of anyone trying that.So I tried it.The worse thing that could happen would be that it wouldn't make power.And that's exactly what happened</TD></TR></TABLE>
Well the header look diffrent.
Old Feb 22, 2005 | 08:14 PM
EMO-anthony's Avatar
looks sick....
Old Feb 22, 2005 | 08:15 PM
johnzm's Avatar
Default Re: (RMF)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RMF &raquo;</TD></TR><TR><TD CLASS="quote">It started off .I was just going to straighten out the exhaust ports.And raise the floor.But I couldn't flow each valve separate.So I brought the divider out to the end
of the port.
Modified by RMF at 8:51 PM 2/22/2005</TD></TR></TABLE>
really apprecite it, i had been thinking about this for MONTHS ever since i found this
beautiful isint it
RMF, have you been able to try moving the collectors closer to the exit as those are on that engine?
Old Feb 22, 2005 | 08:29 PM
RMF
Guest
Posts: n/a
Default Re: (johnzm)
Thats next I just wanted to try puting 1/2 the port in one collector and the other half in another.The way your talking about works for sure.Most of the european
built race motors are like that.It really picks up the torque.
Old Feb 22, 2005 | 09:06 PM
mike_belben@yahoo.com's Avatar
From: not riding any bandwagons in, massachusetts, usa
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LsVtec92Hatch &raquo;</TD></TR><TR><TD CLASS="quote"> but i just have one question....
Since the 'wall' (dont know the technical term here) that divides the exhaust port smoothes out and ends (obviously) before the head casting 'ends', what benefit does setting up those two chambers in the front of the primaries add?</TD></TR></TABLE>
youre looking at it backwards. i was too for a while.
Old Feb 22, 2005 | 09:14 PM
EdBoon's Avatar
All I wanna know is what types of header options do I have with RMF and how much? PM me please. Thanks
Old Feb 22, 2005 | 09:41 PM
blackstar's Avatar
war all of the time......
Default Re: (RMF)
very nice!!! interesting ideas for the head work. that header looks crazy!! would it have worked better with bigger primaries?
Old Feb 22, 2005 | 09:49 PM
Default Re: (mike_belben@yahoo.com)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mike_belben@yahoo.com &raquo;</TD></TR><TR><TD CLASS="quote">youre looking at it backwards. i was too for a while. </TD></TR></TABLE>
Well, paint me green and call me gumby, youre right.
Old Feb 22, 2005 | 09:52 PM
AllmotaB18EH2's Avatar
Default Re: (blackstar)
Old Feb 22, 2005 | 10:47 PM
ShaunRR's Avatar
HT White Ops
Community Builder
Nobody listen to this Randy guy, he doesn't know what he's talking about. He just welds tubes together.
Old Feb 22, 2005 | 10:51 PM
ctap's Avatar
damn that looks crazy
Old Feb 22, 2005 | 11:34 PM
WrongWD's Avatar
haha damn, keep the header off and the plug wires covered and tell everyone its really an 8cyl, 40mm bore
Old Feb 23, 2005 | 01:20 AM
Rocket's Avatar
Default Re: (WrongWD)
Randy, you're a madman!
Old Feb 23, 2005 | 05:41 AM
Speedz's Avatar
Default Re: Crazy Custom RMF header and b16 Head with major mods (EdBoon)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EdBoon &raquo;</TD></TR><TR><TD CLASS="quote">All I wanna know is what types of header options do I have with RMF and how much? PM me please. Thanks</TD></TR></TABLE>
http://www.importpowerhouse.co....htm#
edboon check that website
Old Feb 23, 2005 | 09:24 AM
ImportechPerformance's Avatar
Pure crazyness...in da cabeza.
Old Feb 23, 2005 | 09:31 AM
civicross's Avatar
Default Re: Crazy Custom RMF header and b16 Head with major mods (ImportechPerformance)
I have a formula one motor here at tuners choice that has individual runners for each valve, so it does obviously work, as they wouldn't have ran the motor if it didnt. I don't have a picture of that particular one but i'll try to grab one sometime this week.
One of the motors we have, i'll grab the other pic sometime this week.
Old Feb 23, 2005 | 09:46 AM
Chris_Bye's Avatar
Default Re: Crazy Custom RMF header and b16 Head with major mods (civicross)
these are some crazy headers
